NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 28, 2020 at 1:35 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Same here. No loss of fluid in the reservoir but I had a small puddle down by my passenger tire when I first noticed it. Tie Rod boots are still damp. I have no idea where the fluid is going or coming from if there's no loss. It makes no sense to me lol. But I do have a new rack/tie rods and high pressure line to throw in the truck once it warms up again. Probably going to get a new half shaft as well as recommended by others...just in case.
  2. Dec 28, 2020 at 3:58 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I ended up finding a crack in the boot so that explains the wetness. Grease was leaking out.
    I’m still torn between changing the whole rack or just tie rods. Pat is making me think I’ll be ok with just tie rods, but for $140 more I could do the rack too..
    but I really don’t feel like doing to work to change the whole rack..
    might order the whole rack and only install the tie rods. Then I’ll have a spare rack..
  3. Dec 28, 2020 at 5:12 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Not sure where are you looking to buy your inner tie rods, but a little while ago Low Range Off Road had 2nd gen inners at pretty competitive price (They don't fit turd gens , so I didn't get them). Worth checking out if they still have/stock them.
    HomerTaco likes this.
  4. Dec 29, 2020 at 9:28 AM
    JLink
    Josh
    Ocean, NJ
    not oem, but they say they’re oem quality, and way cheaper. Gonna order a set. Thanks
    Bastek[QUOTED] likes this.
  5. Dec 29, 2020 at 8:27 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    i always figured the rack was a wear item, just like a differential, a transmission, or anything that has constant movement and mechanical interaction along with high pressure fluids involved. The steering box on my f350 was worn and I could turn the wheel about 15° before the tires started rotating, replaced it with a red head box. Do sector shaft steering setups have a different wear than a rack and pinion setup?
  6. Dec 29, 2020 at 8:45 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :notsure:
  7. Dec 30, 2020 at 5:11 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    I just interacted with the biggest cunt ever on a Facebook overlanding group. Fuck this guy I’m sticking with TW
    this was his response to us asking the location he wheeled at
    “ Am I obligated to? I researched it, mapped it, plugged it into Gaia, pre ran it with group members. I did all of that just to make someone’s life easier? I host group runs all of the time, your welcome to join on the next one. “
  8. Dec 30, 2020 at 5:24 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Looks like a glorified dirt road anyways
  9. Dec 30, 2020 at 6:00 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    He’s on here too. :popcorn:
    Taco_Coma and Checkers10160 like this.
  10. Dec 30, 2020 at 6:07 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    well to be fair, a lot of people wont openly share details to their off road spots...
    its akin to sharing a secret surf spot or fishing spot.
    especially in the north east where things like BLM is not exactly a thing we have...
    if you read through this NJ thread alone, you will see many have shared that cunts reply...
    :spy:
    for better or worse, not trying to take sides, just saying his reply was more typical than some may want to believe, gotta remember a lot of our off road spots are questionable at best if not blatant trespassing, that usually has a part in it as well.
    nobody wants to blow the spot up
    enough people who dont pack out what they pack in so...
    I would just take the cunts reply with a grain of salt thats all
  11. Dec 30, 2020 at 6:13 AM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    Yeah I don't want to take sides but I definitely see it here as well. I'm most active in NY/CT threads but it's definitely not uncommon for people wanting to keep their spots secret. Although honestly I feel like both people could be more polite...
  12. Dec 30, 2020 at 6:18 AM
    uurx
    '12 t|x pro
    it always helps trying to join a group and become friendly with them first, then they are more inclined to share or invite
    in the end though really all these spots are mentioned online in one way or another the dark web knows no boundary
    just gotta research, maps, and techy shit like GAIA :anonymous:
    Bastek likes this.
  13. Dec 30, 2020 at 8:26 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    soooo... where is it?
  14. Dec 30, 2020 at 9:49 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    He’s probably just trying to keep wannabe “overlanders” from the big city from showing up and ruining what little “offroading” NJ still has
    The Hunter and JDUB-Fabrication like this.
  15. Dec 30, 2020 at 10:50 AM
    Anchovy
    TRD Ferguson
    It’s probably his dads back yard on the farm
  16. Dec 30, 2020 at 11:31 AM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Secret road to pepboiz
  17. Dec 30, 2020 at 11:46 AM
    JLink
    Josh
    Ocean, NJ
    If that’s “the biggest cunt” you’ve ever interacted with, you must be new to the internet.
    most people will not share their offroad spots with strangers on the internet. But he did invite you to join the next group.
    you want some suggestions on where to go wheeling? Check out rausch creek or anthracite outdoors adventure area.
  18. Dec 30, 2020 at 12:51 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hey I’m a far bigger cunt than Eric, goddamn no credit in NJBS anymore.
    The Hunter, Bastek, JLink[OP] and 2 others like this.
  19. Dec 30, 2020 at 1:42 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
  20. Dec 30, 2020 at 2:19 PM
    uurx
    '12 t|x pro
    ftfy :hattip:
    JLink[OP] likes this.
