NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 9, 2021 at 8:47 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I've never bothered, in fact for most pickups it's recommended to run higher pressures. I run 35 psi all the way around, then when I rotate tires I don't have to worry about adjusting pressures.
  2. Jan 9, 2021 at 8:49 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    HomerTaco and Wheelspinner like this.
  3. Jan 10, 2021 at 6:40 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    CaliRaised Bed Stiffners $75
    I live in DC but travel to Philly often as family is there. Planning a trip in the next 5-10 days. Happy to meet to hand off if you want them.
    SALE PENDING
    E-Paz 732NJ likes this.
  4. Jan 10, 2021 at 1:07 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Are these available?
    Wheelspinner likes this.
  5. Jan 10, 2021 at 1:12 PM
    Sheepnick1
    Sheepnick1 TacoJerry.com
    Nick
    Lynchburg Virginia
    2019 Tacoma trd off road
    Out of curiosity why are you selling these? I have this set that I'm about to install. Just making sure I'm not going to mess anything up with putting these on my tacoma!
  6. Jan 10, 2021 at 1:40 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    You're not messing anything up. Totally worth it for peace of mind not to mention the additional tie downs always come in handy.
    Sheepnick1[QUOTED] likes this.
  7. Jan 10, 2021 at 2:36 PM
    Overland&UpMoutains
    Parker
    Deleware
    Yes, pm’d you
    no you won’t mess anything up, just switched to flat ones as I don’t need the extra tie downs
  8. Jan 10, 2021 at 7:11 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    In the market for a 14-16 foot jon boat if anyone has or knows someone who has one... with or without engine. Prefer 48 or wider. 3 grand cash in hand
  9. Jan 10, 2021 at 7:56 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    needs new paint and a new beak job but asking $3750, don’t lowball me I know what I have.
  10. Jan 10, 2021 at 10:45 PM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Flat bottom?
    The Hunter[QUOTED] likes this.
  11. Jan 11, 2021 at 5:25 PM
    Overland&UpMoutains
    Parker
    Deleware
    if you want it let me know asap
  12. Jan 12, 2021 at 5:34 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    flat bottom or semi flat with a front V. I found a few. 1 in seaside a 1648 that the guy is waiting on the title for just needs an outboard. Other is a bit smaller 1438 with motor but the guy keeps dodging me when I ask if I can run the engine when I come look at it
  13. Jan 13, 2021 at 9:30 AM
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    $3k cash your choice no titles :D
    656E8434-5713-4086-BFEB-A5FF53091F34.jpg 0BE3070B-8D42-416D-848B-FB9474CC8AE4.jpg D0789FA2-0CD3-4B72-875E-EF728FF56AFB.jpg
    Nimble9 and uurx like this.
  14. Jan 13, 2021 at 12:36 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Is this still available?
  15. Jan 13, 2021 at 12:47 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    How much for this?
  16. Jan 13, 2021 at 4:50 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I'd rock the fuck out of the one w/ the 3.3
  17. Jan 13, 2021 at 6:35 PM
    chad_chinchilla
    chad_chinchilla Well-Known Member
    Nick
    Toms River
    2017 TRD O/R
    that lonngboard for sale :D
  18. Jan 13, 2021 at 7:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the silver dumpster? They usually run around $30 a month to rent.
    Fifthwind and HomerTaco like this.
  19. Jan 14, 2021 at 3:02 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    lollll need title to register.
  20. Jan 14, 2021 at 4:29 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Don’t be a pu$$y, I don’t even register my truck:rolleyes:
