NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Oct 9, 2021 at 12:19 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    That's the one that is in there now. The 4wheel drive has been giving me trouble prior to that, it would take some work to go in but at least it would go into 4 wheel drive. The last time I really used it and it worked was last October when I went to Florida and back in November was my last trip to Rausch. I did find out too during the last time I went to Rausch that my rear e locker stopped working too. Last spring I did loose a u joint and it also wiped out the 4 wheel drive switch on the transfer case. A local shop replaced that when they replaced the drive shaft so that is new too. But it hasn't been working since then. When you turn on the the 4 wheel drive you can here the switch engage on the transfer case and the 4 wheel drive ECU clicks once. I did buy a new ADD actuator. I didn't install it but I did plug it in and its not doing anything, but if I disconnect the ADD and leave it unplugged all the dash light light up. So there is some kind of signal getting to the ADD. I'm not sure really where to go from here, I'm trying to avoid taking it to the dealer. I don't trust a lot of mechanics anymore.
  2. Oct 9, 2021 at 7:47 AM
    dvalente98
    dvalente98 Well-Known Member
    Dylan
    any surf fisherman start getting stocked up on sp minnows for the fall run? Apparently the shortage of tackle is gonna be real bad this year... just like everything else
  3. Oct 9, 2021 at 5:04 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Pells in Brick has been stocked up on them every time I've been in there.
    dvalente98[QUOTED] likes this.
  4. Oct 9, 2021 at 6:06 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    damn…
  5. Oct 10, 2021 at 9:40 AM
    The Field Archer
    The Field Archer Well-Known Member
    North New Jersey
    15 Tacoma Double Cab 4x4 TRD Sport
    Abject4x4, E-Paz 732NJ and mptski78 like this.
  6. Oct 11, 2021 at 6:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    NJ looks bigger than I remember.
    E-Paz 732NJ, uurx and dvalente98 like this.
  7. Oct 12, 2021 at 5:52 AM
    Jlab
    Jlab Well-Known Member
    Justin
    Utah
    2020 Cement TRD OR DCSB
    I’m visiting Jersey for a few weeks and I’ve got my truck any one in the Monroe township/williamstown area wanna explore some trails?
    just trying to avoid the mud if that’s possible here.
  8. Oct 12, 2021 at 6:58 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    im about 10 minutes from there, lots of trails to check out not too far away. Winslow WMA has some nice sections or at least it used to.
    Jlab[QUOTED] likes this.
  9. Oct 12, 2021 at 7:01 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    After the fire they’re heavily patrolled, or they were last time I tried
    6 gearT444E[QUOTED] likes this.
  10. Oct 13, 2021 at 5:07 AM
    Jlab
    Justin
    Utah
    is it illegal to go explore them?
  11. Oct 13, 2021 at 5:26 AM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    Pardon my ignorance, what is this part?
  12. Oct 13, 2021 at 6:40 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  13. Oct 13, 2021 at 6:46 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    if your vehicle is registered and insured it is legal. Be aware that hunting season is starting soon and you may get some angry looks from small game folks out there.
    https://www.nj.gov/dep/fgw/smgame_info.htm
    Taco_Coma and Jlab[QUOTED] like this.
  14. Oct 14, 2021 at 9:51 AM
    LSKinetic
    LSKinetic ah beans
    NJ
    2001 Tacoma TRD OR V6 5speed
    so I forgot about the shocks, been driving my BRZ a lot more recently but took the truck in today and noticed a clanking noise from the rear.
    I figured it out.
    JLink[OP] likes this.
  15. Oct 14, 2021 at 10:50 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yup, that will definitely make it ride like shit. I've driven on no rear shocks once to @6 gearT444E's place and it was fucking terrifying.
    HomerTaco and 6 gearT444E like this.
  16. Oct 14, 2021 at 10:58 AM
    LSKinetic
    LSKinetic ah beans
    NJ
    Yeah will probably be getting new shocks this weekend.
    Has anyone run 5100s with no lift and can recommend it?
    I'd prefer not to do AAL of lift blocks, but the ability to level the front a bit would be nice.
  17. Oct 14, 2021 at 11:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Your best bet is searching titles for 5100's in the first gen section for more info. Not enough first gen's in the local NJ thread who can give good opinions.
  18. Oct 24, 2021 at 10:44 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Had the opportunity today to visit one of the 7 wonders of the world. The lost city of the Incas, Machu Picchu, during my honey moon in Peru.
    Wanted to share these nice shots.
    Also went up to the very top of Huanapicchu mountain/ 2,693 meters above sea level.
    Tomorrow I will attempt to hike up to top of the "Mountain of 7 colors" (5,200 meters above sea level)
    Toy4me, jrzyshore, Lux and 15 others like this.
  19. Oct 25, 2021 at 5:53 PM
    JDUB-Fabrication
    JDUB-Fabrication Well-Known Member
    Newburgh NY
    2010 Lexus GX460
    Quick X-mas tree run to test out the new rig. Picked it up in GA, rust free, but not for long. (Yeah sold the Tacoma)
    Didn’t see any patrols, or anyone for that matter. Especially quiet run in north jersey last weekend.
    CFEF74E4-F536-4A31-866E-957D2788174C.jpg 42E06849-FFC0-4D74-920A-312D70B0F75D.jpg E0CB8593-93FE-4FD0-9D08-0E274289BE1F.jpg
    V5ioV, E-Paz 732NJ, Bastek and 4 others like this.
  20. Oct 25, 2021 at 6:15 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Anybody looking for a working OEM front diff actuator for a 2nd gen in good condition let me know. Found this one on the shelf when cleaning up. I took it apart to check the condition, contacts, gears, and motor are in good condition. All the limits work. Will make a good deal to someone local, Toyota wants around $300 for these new. Otherwise I'll post in the BST section next week most likely.
    V5ioV likes this.
