NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Feb 25, 2022 at 6:27 AM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Yeah, it’s crazy how bad the salt is on Toyota frames in particular. My 2019 had 30k miles on it when I sold it. 15 months driving and I tried to keep it out of the salt and all the welds were rusty and the control arms starting. I couldn’t believe it.
  2. Mar 1, 2022 at 9:04 AM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Anybody in here work on commercial diesel trucks or have knowledge and can potentially help?
    Peterbilt work truck is throwing codes for contaminated DEF and its sensor 2 days after it's PM service at Peterbilt (and has been sitting at the dealer since that, we noticed the dash lights when we picked it up that they didnt see?). How does DEF become contaminated as we never had these codes before it was at the shop? Peterbilt is trying to say it is 8 hours labor (and could have been more but "they took off some labor hours off the bill") to drop DEF tank, drain/blow out lines and replace some filters which seems rather outrageous. I kinda feel something fishy with it considering we buy all our DEF in drums from this dealer but I'm also not a diesel mechanic, clearly :notsure:. Any help, helps! Sorry its not a Taco post.
    uurx likes this.
  3. Mar 1, 2022 at 9:23 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I can’t imagine a def sensor being terribly difficult to replace, it probably uses conductivity or something to determine the condition of the fluid. Find the def tank and the sensor won’t be far away I’m sure.
    E-Paz 732NJ[QUOTED] likes this.
  4. Mar 1, 2022 at 9:42 AM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    They also said they tested the DEF and that it was out of spec which is why they would need to drain and flush. That its supposed to be 32% urea the rest deionized water, and its 35%. But when you put it that way, could they be telling me its at 35% to get more labor hours out of it when it could only be the sensor? They never sent me any readings or documentation on the DEF spec testing showing it was at 35% unless its just something the computer can read.
    It was already at the shop and we didn't really have the chance to bring it back here since they said it could go into limp mode and my driver ended up leaving it. It is all pretty easily accessible as its all mounted on the outside of the truck near driver door/gas tank.
  5. Mar 1, 2022 at 9:45 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    id ask for some more documentation and results of that test yes. An out of spec reading should be confirmed with a known calibrated instrument before suspecting either the fluid or the sensor is at fault. Sounds weird that would happen if it wasn’t like that before you gave it to them, especially if they are saying the fluid actually is out of spec.
  6. Mar 1, 2022 at 9:55 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    delete def system
    fuck the law
    problem solved :hattip:
    E-Paz 732NJ and 6 gearT444E like this.
  7. Mar 1, 2022 at 12:28 PM
    E-Paz 732NJ
    Eric
    NJ
    2015 Tacoma TRD-OR
    My exact thoughts, something seems little weird to me. And i dont know too much about DEF. But fuck they could have dropped some tap water in the DEF tank for all i know just to throw it off. I'd hate to think any tech/dealer would do that but i guess never know with some.
  8. Mar 1, 2022 at 4:47 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    If the urea reading is at 35% instead of 32 that means adding the proper amount of water would get it back in the correct measurement. Is it possible that the water portion evaporated either from the drum prior to filling or from the truck?
  9. Mar 1, 2022 at 7:19 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    These emissions systems are pretty easy to diagnose. DEF doesn’t really go bad unless sitting for long periods of time. but the DEF sensor is inside the tank and part of the sending unit. depending on the location of the tank and where the lines have to go from to get to the back of the DEF injector this could take time. I work on the machine application side of it but they are all the same.
    Id say 8 hours is a generous quote though dealerships always quote high and never take back the time they quoted high for. Ill bet it took an experienced tech 5 hours to disassemble and reassemble the entire system not sure why they would flush the lines with air though considering DEF dissolves in water when in crystal form I always flush with water back to tank flush the fill neck tube to tank and remove tank drain it and wipe it out. I just did the DEF heater and pump on my 16 duramax work truck.
    the filter in a DEF system is also in the tank on the pick up tube. some look like a felt sock others are odd shapes and small and clip onto the end of the line. Id like to know what the codes they found actually were what they mean and the troubleshooting steps they used to come to the root cause of the issues.
  10. Mar 1, 2022 at 7:19 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    youre looking at borderline jail time now for running deleted trucks.
  11. Mar 1, 2022 at 7:38 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    3 free hots and a cot is better than what some people get on the outside the way the country is going these days :rofl:
    not_nick and The Hunter[QUOTED] like this.
  12. Mar 2, 2022 at 4:07 AM
    uurx
    '12 t|x pro
    wait what was that story remind me again
    your friend got arrested but quickly lawyered up an then shortly released, all after buying a full size diesel off craigslist with a def delete kit? wild stuff...
    Wheelspinner likes this.
  13. Mar 2, 2022 at 5:08 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    :worthless:
  14. Mar 2, 2022 at 6:15 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    I’m sorry who are you? Maybe you should meet someone before you bust their balls. Its not nearly as funny when strangers do it.
    Though if you must know that was from the DOT trooper that stopped me last week to check my truck.
    pics of the duramax work truck? Its just a company truck. 2016. Nice ride.
  15. Mar 2, 2022 at 6:25 AM
    uurx
    '12 t|x pro
    chill out nipple lips, we ate hot dogs together at rausch, i am offended you dont remember me
    tells us more about this trooper and how you almost went to jail time last week though :boink:
    Kindadinosaur and MY50cal like this.
  16. Mar 2, 2022 at 6:43 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    don’t know you from a hole in the ground. My dot check went fine but that’s what they’re out looking for. There was a check point in hammonton last week
  17. Mar 2, 2022 at 7:00 AM
    uurx
    '12 t|x pro
    how about that hole in the wall?
  18. Mar 2, 2022 at 7:00 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that's where the hot dog goes.
    Anchovy, planters15, Bastek and 4 others like this.
  19. Mar 2, 2022 at 7:26 AM
    uurx
    '12 t|x pro
    i always take mine in the buns
    :rocket:
  20. Mar 2, 2022 at 9:09 AM
    RubyTaco21
    RubyTaco21 Almost Known Member
    NY
    Barca Red SR-5 with some mods.
    I got no dog in this fight, but a word of caution from personal experience: Be careful posting any pics of your work ride that includes the company phone number on it unless you're the one who answers the phone.
