NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Nov 18, 2013 at 6:00 AM
    #7601
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Still got your y pipe if you need it back, then you fan sell the DT. Hit me up via cell. We can work someyhing out for sure.
  2. Nov 18, 2013 at 6:13 AM
    #7602
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thanks haha I have cut pieces of angle iron I mounted to the front radiator support and have the lights hanging upside down. Unfortunately since I have so little space back there since the billet grill takes up a lot of space they have to get re-aimed often. I hope to get a BAMF setup eventually and hopefully fix that. I'll try to get pics the next time the grill is off.
    Thanks!
    Yeah I think I'm going to run 1" spacers until I can afford some SCS wheels. I got the alignment done when I got the tires put on. It will give me the wider stance I want too I think. Hopefully I can hit up my buddy with a garage in a sometime soon so I can get the locker fixed for RC.
  3. Nov 18, 2013 at 6:29 AM
    #7603
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    :spy: If I was closer... and had money... and didn't need tires first :(
  4. Nov 18, 2013 at 6:32 AM
    #7604
    NC15TRD
    Nick
    PA
    It worked on mine! I used an old truck tire inner tube and cut a couple pieces and wrapped the ends
  5. Nov 18, 2013 at 6:32 AM
    #7605
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
    I'll go :D
  6. Nov 18, 2013 at 6:34 AM
    #7606
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Thanks for the feedback
  7. Nov 18, 2013 at 6:43 AM
    #7607
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    Alright cool! I'm going to see if I can put the lights that I have in there...i have 2 4inch round leds. After seeing 01tacomas mirror lights...it's making me consider putting them there too. Are u still plannin to come to rausch?
  8. Nov 18, 2013 at 6:45 AM
    #7608
    porchop
    Brad
    NJ
    '15 TRD PRO S/C
    Welcome bud :wave:
  9. Nov 18, 2013 at 6:55 AM
    #7609
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    CB newb question for you guys -
    The antenna stud tells me to mount it in the folowing order from the bottom up
    Stud - nothing - Comet mount - plastic washer, metal washer, lock washer, coupling nut
    Can I replace "nothing" with a metal washer? The hole is just too big for the stud and the coupling nut on the bottom doesn't hold it in place well, not sure why...
  10. Nov 18, 2013 at 7:03 AM
    #7610
    porchop
    Brad
    NJ
    '15 TRD PRO S/C
    Text mike lol he fixed mine and tuned it
  11. Nov 18, 2013 at 7:14 AM
    #7611
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    We disagree about this lol. I don't think my comet mount is serving as a ground (since it came with no instruction, i have no idea, but my multimeter says it isn't, neither is the painted surface its mounted to. If it is serving as a ground, that washer may make unwanted connections, but that bottom coupling nut would be touching the metal anyway. I'm not sure. maybe I have the wrong stud or something, but it says it fits all firestiks and blah blah blah. My stupid antenna should be here today and i'm gonna attempt the install tomorrow - i have to cut some paneling and route the cable and wire it up which i can hopefully do in my 6 hours between classes
  12. Nov 18, 2013 at 7:20 AM
    #7612
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hell yeah man. I will be coming for Friday wheeling, and staying into Saturday. You should have no problem getting 2 4 inch LED's back there. My Hella's are 7 inches I think? The problem is in their depth but even so there is enough space to aim them.
  13. Nov 18, 2013 at 7:25 AM
    #7613
    NC15TRD
    Nick
    PA
    :thumbsup:
  14. Nov 18, 2013 at 7:25 AM
    #7614
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    Oh yeah, Brad, did all your shit come?
  15. Nov 18, 2013 at 7:30 AM
    #7615
    XXXX
    sKiP
    05 Prius
    No idea what mount your using but here is how it should be done and you should be running a grounded antenna. If you bought a "no ground plane" type return it.
    If your putting it somewhere that's not grounded - run a ground wire to the bottom. If you are trying to ground through paint or powdercoat it's not going to work. Need bare metal.
    41096d1299375031-cb-antenna-mount-img_18_a5e599968a3d18583c496a60f0677a170ae0f0d9.jpg
  16. Nov 18, 2013 at 7:33 AM
    #7616
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    Thats what I'm confused about. I'm using 259 connectors which, to my knowledge, the inside male part is hot and the outside is ground - see left most image below. Thus, the connection should ground the mount, right? I linked the mount below too. So, it shouldn't matter if I throw another washer underneath the mount because it'll just help the "outside" ring of the 259 ground the mount. Does that make sense?
    http://www.cheapham.com/products/Comet-RS%2d720-Lip-Mount.html <<<< MOUNT
  17. Nov 18, 2013 at 7:37 AM
    #7617
    XXXX
    sKiP
    05 Prius
    Yes.... and if the mount is not grounded simply run a ground wire to it on the bottom. That white bushing for the top has a outer lip to keep the top portion of the connector from touching the sides of the hole.
  18. Nov 18, 2013 at 7:39 AM
    #7618
    XXXX
    sKiP
    05 Prius
    and.....WTF kind of mount is that? I'd ground that sucker to the frame. My antenna is mounted to my plate bumper and I still have an aux ground running to the frame.
  19. Nov 18, 2013 at 7:39 AM
    #7619
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    Right that's what I figured. So I'm in good shape then :D
  20. Nov 18, 2013 at 7:40 AM
    #7620
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    DT Y-pipe too? Curiouser and curiouser....
