NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Nov 25, 2013 at 12:17 PM
    #8101
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    I hope you got a name from the 1st person that told you $120-$150....
  2. Nov 25, 2013 at 12:21 PM
    #8102
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Was that $120-150 figure per shock or total?
  3. Nov 25, 2013 at 12:24 PM
    #8103
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    I'm assuming that's why it broke
    I do
    Trying to find that out
  4. Nov 25, 2013 at 12:27 PM
    #8104
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Get him/her to honor what they originally said..mm
  5. Nov 25, 2013 at 12:35 PM
    #8105
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I have the TSB add a leaf. After Christmas I want to replace them with a set of Dakars and flip the U bolts.
    That's a big difference.
  6. Nov 25, 2013 at 12:45 PM
    #8106
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Not sure about Icons.... but Kings requiere a longer eyelet to be used with the a Dakar LP.... make sure to ask
  7. Nov 25, 2013 at 12:48 PM
    #8107
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Something similar applies to the Icons also. DSM has the Icons built to work with the Dakars and it's different enough from the regular extended travel shocks that you have to ask them to do it. Definitely check with them before you order, or you might find yourself needing to order another set of shocks later to work with the Dakars.
  8. Nov 25, 2013 at 12:49 PM
    #8108
    jrzyshore
    Scott
    SNJ
    :thumbsup: Thanks I will.
  9. Nov 25, 2013 at 12:50 PM
    #8109
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I would assume you can just swap eyelets
  10. Nov 25, 2013 at 12:58 PM
    #8110
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    ahhh good ol used suspension. Yea live and learn. I got burned by it. Never again will I buy anything used like that or electronics. When Chris and I swapped thirds I could look at his bearings, fluid, and the gears. With suspension or electronics you are clueless as to whats inside or how they were treated.
  11. Nov 25, 2013 at 1:06 PM
    #8111
    jrzyshore
    Scott
    SNJ
    :notsure:So I guess that means you don't want to buy a self lubricating Bilstein 5100 with only 1 inch of travel for a good price.
  12. Nov 25, 2013 at 1:10 PM
    #8112
    Monster Coma
    Corey
    yup.. Oh well even if this does cost $260 so far I'm still $740 ahead..
    and it was $120-130 a shock. Makes sense I guess
  13. Nov 25, 2013 at 1:16 PM
    #8113
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Are you getting resi mounting brackets?
  14. Nov 25, 2013 at 1:19 PM
    #8114
    Monster Coma
    Corey
    Yes, I'm just gonna send the shocks to fox. It will be about $205 to have it repaired, rebuilt, and revalved
  15. Nov 25, 2013 at 1:29 PM
    #8115
    XXXX
    sKiP
    05 Prius
    Mine looks much worse. Is that after you cleaned it? Mine is black from a mixture of dust/mud/oil
    I gotcha, but I hate doing things twice unless it's a chick
  16. Nov 25, 2013 at 2:16 PM
    #8116
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    FTFY
  17. Nov 25, 2013 at 3:21 PM
    #8117
    jrzyshore
    Scott
    SNJ
    Mine did look like that for the longest time because it started to seep last year. The seal finally gave out making a mess of the frame, leaf spring, wheel, tire and it was dripping all over the driveway. When I took it off I notice something must of came a part inside because it will only compress about an inch. I am pretty sure all the fluid that was in it cleaned the outside off.:eek:
  18. Nov 25, 2013 at 3:39 PM
    #8118
    XXXX
    sKiP
    05 Prius
    I'm not picky :)
  19. Nov 25, 2013 at 4:59 PM
    #8119
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No shit! :laughing:
  20. Nov 25, 2013 at 5:37 PM
    #8120
    jrzyshore
    Scott
    SNJ
    :eek:
