NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 29, 2014 at 7:11 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    That post was actually done on the laptop.... but phablets ftmfw
  2. Jan 29, 2014 at 7:13 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Where would phablets rank against manuals on the ftmfw list?
  3. Jan 29, 2014 at 7:16 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    We would have to compile two separate lists....
  4. Jan 29, 2014 at 7:21 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    GTFO! I might have to ignore you for this one. :rolleyes:
    Haha touche!
  5. Jan 29, 2014 at 7:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :confused:
    trying to help the poor guy and I'm "yammering on"
    no good dead's go unpunished in here
  6. Jan 29, 2014 at 7:30 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Welcome to NJ. :p
  7. Jan 29, 2014 at 7:36 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Yeah. That plate is a little bent and some of the powdercoat chipped off but nothing a little paint can't fix. Still haven't taken an angle grinder to the hook to get some more clearance for a tow strap.
  8. Jan 29, 2014 at 8:03 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I don't think you need to take much but you can use the clearance just to make things a little easier. But I think you mean taking the grinder to the skid not the hook right?
  9. Jan 29, 2014 at 9:19 AM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    and by reversing and hitting the brakes thats supposed to readjust the e brake right?
    :cool:
    what are we doing now?
  10. Jan 29, 2014 at 9:22 AM
    XXXX
    sKiP
    05 Prius
    I have heard that but I tried it and I think it's bullshit.
    Best case is to just lift the rear of the truck up and adjust the star until the pads are just slightly rubbing the drums. You should still be able to turn them by hand - if you can't they are to tight per what I read.
  11. Jan 29, 2014 at 9:24 AM
    JLink
    Josh
    Ocean, NJ
    good to know
  12. Jan 29, 2014 at 9:25 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    There isn't a lot of clearance around the factory tow hook because of the ARB mounting bracket, so we need to come up with some garage engineering to solve that problem. Or I could just install a winch.
  13. Jan 29, 2014 at 9:34 AM
    JLink
    Josh
    Ocean, NJ
    so what winch are you getting?
    :p
  14. Jan 29, 2014 at 9:37 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Well, all the camera gear sales are over so that frees up some of my toy money. Thinking about a Warn 9500lb one with synthetic line. Going to need an offset Hawse fairlead though to avoid drilling holes in the ARB.
  15. Jan 29, 2014 at 9:37 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Could we just make the opening on the skid tru which the hook come out a little wider?
  16. Jan 29, 2014 at 9:40 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    No, because then I don't get to have a new toy. When my tire was leaking air a few weeks ago I kept reminding my wife that the situation wouldn't be so bad if I had onboard air :D
  17. Jan 29, 2014 at 10:22 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    :eek: I've got to try that one!
    What on board air are you looking at?
    Where u putting it on the truck?
  18. Jan 29, 2014 at 10:26 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Yeah that's a good strategy. ... I told my wife she NEEDS an FJ as her next car.... but i think she's up to my intentions. ...lol
  19. Jan 29, 2014 at 10:30 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    Haha. So if that were to happen, which one would be the recovery vehicle? :D
  20. Jan 29, 2014 at 10:33 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    You guys can adjust your rear brakes by hand??? Damn you.
    The rear brakes are supposed to auto adjust, but at least in my experience that stops working pretty quick. If it is working then setting the parking brake is the best way to keep them adjusted since it will fully seat the rear brakes.
    I believe the reversing and braking thing is either old school thinking that no longer applies or just meant to loosen things up so the adjuster works properly. I forget, I remember reading up on it a while go, could be completely wrong.
    And I wish the term e-brake would be abolished. It's a parking brake, you should always use it regardless of transmission. You auto guys really want to trust your vehicle on a hill solely to a little pin in the transmission?
