NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Mar 26, 2014 at 2:23 PM
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    Ok so I got my ato front skid in the mail today but with no hardware... so do I use the bolts that it lines up with if it does... or do I have to buy them somewhere else
  2. Mar 26, 2014 at 2:38 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    mine came in with hardware... it was in a separate box but wrapped inside with the skid...
  3. Mar 26, 2014 at 2:41 PM
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    I just called them asking if it was supposed to come with hardware and he said you reuse the factory hardware
  4. Mar 26, 2014 at 3:41 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I just got mine on Friday and haven't installed them... but I also got the other 2 skids as well so I guess the hardware is for the other 2.... sorry man didn't mean to confuse you...
  5. Mar 26, 2014 at 3:43 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    You use the stock hardware.
  6. Mar 26, 2014 at 5:23 PM
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    Alright thanks for the info ill start painting it tomorrow after work
  7. Mar 26, 2014 at 5:24 PM
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    No problem I didnt wanna try to put it on and not have something if I needed it
  8. Mar 26, 2014 at 6:28 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    4 17mm bolts from the stock skid supports.
    2 12mm bolts from stock skid.
    Keep all extra bolts from anything you do on your truck... One of my old 17mm bolts from the stock skid supports is now holding chux's passenger brake caliper to his spindle lol.
  9. Mar 26, 2014 at 6:42 PM
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    But it seems like these bolts I have are flimsy and wont holdtheskids weight or a decent hit
  10. Mar 26, 2014 at 8:04 PM
    JLink
    Josh
    Ocean, NJ
    Do you have the bolts I listed? I can't vouch for the trd skid plate but the normal skid is held on by 4 12mm bolts and the 2 supports are held on by I believe 6 17mm bolts. You don't just remove the stock skid, you remove the stock skid supports too.
  11. Mar 27, 2014 at 3:34 AM
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    Im guna guess I have them because I never removed the supports so they must be there
  12. Mar 27, 2014 at 3:44 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    what happened to it? stripped?
  13. Mar 27, 2014 at 3:54 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  14. Mar 27, 2014 at 4:28 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Agreed
    :pccoffee:
  15. Mar 27, 2014 at 4:34 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Lefty loosey righty tighty :facepalm:
    Looks like rain is going to fade out Sunday morning so looks good for mod day.
    :cheers:
  16. Mar 27, 2014 at 4:45 AM
    Monster Coma
    Corey
    Good morning
  17. Mar 27, 2014 at 5:43 AM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    Good morning to you too
    Seems it has quieted down in here again :)
  18. Mar 27, 2014 at 5:44 AM
    Monster Coma
    Corey
    Its nice and mellow
  19. Mar 27, 2014 at 5:51 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :pccoffee: Tis nice......
    Sadly as we all know that will not last long.
  20. Mar 27, 2014 at 6:01 AM
    Monster Coma
    Corey
    *knocks on wood*
