NJ Taco's
Discussion in 'North East' started by DdayIsNear, Jun 15, 2009.
  1. Jan 30, 2012 at 7:30 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I have Demello bolt on sliders, and mine needed a 1/2" drill bit, which I bought at home depot. for a drill I used a big bad ass mason drill my dad had lying around, but if the cordless won't work I'd say rent an electric drill from home depot. My sliders only needed the holes drilled in the underside of the frame, so I used a floor jack to jack the drill up essentially as an upside down drill press.
    I'm sure Anthony will chime in about CBI sliders.. I think he had to drill into the vertical section of frame??
  2. Jan 30, 2012 at 8:45 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Not sure where about in Philly you are, but if you feel like driving out to Coatesville I have a corded drill and right angle adapter you can use. You can finish them up in my garage.
  3. Jan 30, 2012 at 9:16 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    ^^^ just keep an eye on this guy....you might end up locked in his cellar :D
  4. Jan 30, 2012 at 9:20 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That was the best week of my life! [​IMG]
  5. Jan 30, 2012 at 9:24 AM
    XXXX
    sKiP
    05 Prius
    :rofl:
    You put the lotion on your own skin I hope :puke:
  6. Jan 30, 2012 at 9:26 AM
    mjp2
    NJ
    Not me! I opted to get the hose again. :thumbsup:
  7. Jan 30, 2012 at 9:30 AM
    XXXX
    sKiP
    05 Prius
    that sounds wrong in so many ways :D
  8. Jan 30, 2012 at 9:31 AM
    mjp2
    NJ
  9. Jan 30, 2012 at 9:54 AM
    Enigmaaron
    PA
    1st gen superiority
    I do have a bedroom in the basement with no windows and only one door... :spy:
  10. Jan 30, 2012 at 9:55 AM
    XXXX
    sKiP
    05 Prius
    I'm glad I didn't take the tour Friday morning :D
  11. Jan 30, 2012 at 9:59 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  12. Jan 30, 2012 at 10:18 AM
    Enigmaaron
    PA
    1st gen superiority
    Never ask for the tour :devil:
  13. Jan 30, 2012 at 10:18 AM
    DdayIsNear
    DdayIsNear [OP] Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    Craig, 2012 satoshi, frank want
  14. Jan 30, 2012 at 10:33 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I just started it!
    Going to be a while until I work out how I'm going to do them...
    :sorry:
  15. Jan 30, 2012 at 10:58 AM
    muddin
    muddin Well-Known Member
    PA
    2010 Tacoma DC TRD OR
    Bilstein 5100's on all four with some OME 885x's. Brute Force Fab front bumper. Warn winch. Koenig countersteers wrapped with duratracs.
    Yea i got some new bits, i just figured the drill wouldnt have enough juice in general.
    Yea i saw some nice install instructions on the CBIs where a floor jack was used...gotta buy a new one of them too cause the lil one i have at the house dont work no more :mad:
    thanks for the offer! I think i might just run to home depot or a georges tool rental (just built one by my place) and rent one save some drive time and do it in the driveway.
    um....im scared to ask how you found this out??? ha
  16. Jan 30, 2012 at 11:03 AM
    Enigmaaron
    PA
    1st gen superiority
    If you end up needing a right angle adapter I think I picked mine up at Home Depot or Lowe's for around $20.
  17. Jan 30, 2012 at 11:17 AM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Same place and price I got mine. Worth it's weight in gold.
    Also, get a stepped bit. MUCH easier and the bit is a lot shorter. Trust me. I drilled 40 holes for the sliders I had on my first truck. Just need to drill a pilot hole first, then go to work with the stepped bit. Not sure you need a new drill for the task unless your drill is FUBAR.
  18. Jan 30, 2012 at 3:27 PM
    Altdawg24
    Altdawg24 Member
    Frank
    Flemington, NJ
    2012 Tacoma TRD Sport, extended bed
    All access tannu cover,
    si papi si
  19. Jan 30, 2012 at 3:34 PM
    Altdawg24
    Altdawg24 Member
    Frank
    Flemington, NJ
    got the pictures of my 2012 up! Ol' smokey is def wanting a satoshi grille! :D one of these weekends soon i will def want to get some mud on my tires!
  20. Jan 30, 2012 at 3:56 PM
    JLink
    Josh
    Ocean, NJ
    still want to borrow them to see how my mpgs die
