NJ Taco's
Discussion in 'North East' started by DdayIsNear, Jun 15, 2009.
  1. Jun 28, 2012 at 7:20 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Is there enough room for activities? :D Eddie what kind of car is it?
  2. Jun 28, 2012 at 7:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Dude......Id slap you to get you back to reality if you were closer.
    Your going to risk blowing up your engine to save a few bucks instead of driving one of you other two fully functional vehicle :confused:
    Holly shit your cheap, to the point of costing yourself more money.
    lol :)
    My new names...skip :D
    I think his new name should be "Crazy Eddie"
  3. Jun 28, 2012 at 7:38 AM
    DdayIsNear
    DdayIsNear [OP] Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    Activities, lol, Love that movie.....04 sentra, like mikes 24 hrs of lemons car
  4. Jun 28, 2012 at 7:43 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    how many miles on that motor? piston push back springs probably worn out too. I'd change those too
  5. Jun 28, 2012 at 7:49 AM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    190k. Everything else is great. Run smooth, fuel pumps on these have always been shit and don't break, but suck.
  6. Jun 28, 2012 at 7:50 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    its not that hard you can do it eddie
    if your not sure and it can hold off tell sunday
    ill help you put it in the AM
    just have all the parts
  7. Jun 28, 2012 at 7:54 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    So you are open on Sundays now? :cool:
  8. Jun 28, 2012 at 8:01 AM
    David Tarantino
    N.J.
    08 tacoma
    NO
  9. Jun 28, 2012 at 8:03 AM
    jrzyshore
    Scott
    SNJ
    Dave left on vacation and came back with Sunday hours.:woot:
  10. Jun 28, 2012 at 8:09 AM
    David Tarantino
    N.J.
    08 tacoma
    NO NO NO NO NO NO AND NO
  11. Jun 28, 2012 at 8:09 AM
    David Tarantino
    N.J.
    08 tacoma
    BY THE WAY I HATE YOU ALL
  12. Jun 28, 2012 at 8:10 AM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    Ok, I'll be at the shop 9 am Sunday, gotta love the new Sunday hours.
  13. Jun 28, 2012 at 8:12 AM
    David Tarantino
    N.J.
    08 tacoma
    ok the key is in the door lock up when your done
  14. Jun 28, 2012 at 8:38 AM
    TacomaRockStar
    TacomaRockStar Well-Known Member
    LUCA
    Bayville, NJ
    2024 OR
    Interior carbon overlay, TRD Skid plate, lasfit switchback DTRL, glove box fix, 5% ceramic tint, SXTH Element trail pipe, Lower front fascia delete,
    So my friend works at a Ford dealer and he's going to put the shocks together for free. Is there anything I should tell him as far as what goes together? Like the top plate I got to achieve the full 3"?
    Thank you
  15. Jun 28, 2012 at 8:54 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    You should ask toytec.
  16. Jun 28, 2012 at 8:59 AM
    jrzyshore
    Scott
    SNJ
    The top plate goes on after the spring is assembled between the top of the spring and the shock tower. I only did the 1/4 inch spacer to correct the driverside lean but the 3/4 plate should have came with longer stud. Set the clip on the second notch from the bottom that is .85. Other then that they are pretty straight foreword they pretty much go together as they came apart.:)
  17. Jun 28, 2012 at 9:05 AM
    JLink
    Josh
    Ocean, NJ
    That's the important part
  18. Jun 28, 2012 at 9:06 AM
    jrzyshore
    Scott
    SNJ
    I would do that to because I called about the 3/4 spacers before and I pretty sure Toyotec explained to me that I would move the 1/4 inch spacer to the pass side and the 3/4 on the driverside to correct the lean. But don't quote me on that I could be wrong. Give them a call they always seem willing to answer questions.
  19. Jun 28, 2012 at 9:25 AM
    JLink
    Josh
    Ocean, NJ
    Sounds correct. Taco lean is usually 1/2" lower on driver side
  20. Jun 28, 2012 at 10:02 AM
    TacomaRockStar
    LUCA
    Bayville, NJ
    2024 OR
