NM v2.5 fully adjustable short shifter is now available to the tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NashMan, Mar 23, 2023.
  1. Mar 23, 2023 at 8:34 PM
    NashMan
    NashMan [OP] Well-Known Member
    NM Motor sports is proud to now offer the NM v2.5 shifter fully adjustable shifter to the 2nd Tacoma market. We're opening preorders for 4 weeks, from Mar 24 2023 until Apr 21 2023. The discounted preorder price will only be available during this time at 330 cad/240 usd
    I have been making this shifter and improving on it for a long time since 2008 and on for the Toyota Supra r154 and w58 and now I am happy to bring it to the Tacoma market
    https://www.youtube.com/watch?v=5fB_1-8iXV8&t=41s
    This shifter is like nothing anything els on the market for the toyota tacoma, just imaging putting your shifter stick were ever you want it for any seating position with 80% reduction in throw and solid click gate like feel to give you great confidence when selecting your gear. never have to worry about snapping the lower ball off by adding on an addon or bolts falling into the transmission and trying to source bushing for when you wanna do a re fresh like some others on the market.
    Marc70, TodayWasTHeDaY and shaeff like this.
  2. Mar 23, 2023 at 10:54 PM
    NashMan
  3. Mar 28, 2023 at 8:17 PM
    NashMan
  4. Mar 29, 2023 at 7:22 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Hey Nash, I remember you well from SupraMania.
    Question- 1- what’s done to your truck, sounds like it moves pretty good…
    2- what’s the amount NVH added to the interior? I like the adjustable style, but in the end my Tacoma is the family hauler for vacations and such. I’d imagine some extra NVH with a solid style stick/ no damping like stock or TRD?
  5. Mar 29, 2023 at 11:31 AM
    Parksareforever
    Parksareforever Well-Known Member
    San Diego
    2017 TRD Access Cab
    Does this work on the 4cyl 5 speed?
  6. Mar 29, 2023 at 12:17 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Sounds supercharged, could be wrong but man that thing hauls!
    shaeff likes this.
  7. Mar 29, 2023 at 3:50 PM
    shaeff
    Hudson Valley, NY
    Definitely supercharged, just wondering what else. Sounds quick.
    Edit: I see you said low noise, I’m intrigued…
  8. Mar 31, 2023 at 1:49 PM
    NashMan
    the tacoma one suffers from vibration since the stick is longer vs the r154 being not as loud and just the way the r60 trans is so i added in dampener that stops vibration with a solid ball like the trd ones ect
    as for what I have done is mag super charger one does size in pully to work with oem tune, urd equal headers, valt intake, equal y made by me with 2 vibrant glass pack's 2.25 to 3 inch out back with hooker aerochamber and hp tuners on trd tune and aem fuel pump 375 hp 375 torq
    shaeff[QUOTED] and TegoTaco like this.
  9. Mar 31, 2023 at 1:56 PM
    NashMan
    I don't think it does but I might be able to make it happen i have a feeling it's the same as the first gen tacoma if you can find me pick's of the shifter and what not i might be able to swap out a spacer
  10. Mar 31, 2023 at 1:56 PM
    NashMan
    it has dampener not shown in video
    shaeff[QUOTED] likes this.
  11. Mar 31, 2023 at 6:55 PM
    NashMan
    Marc70 and shaeff like this.
  12. Apr 2, 2023 at 5:59 PM
    shaeff
    Hudson Valley, NY
    Slick, looks neat. Thanks for the update.
    I’m curious about the ability to shift quickly compared to, say, the TRD shifter. I believe that the TRD is 30% reduction in throw, yours is at 80%.
    I’m wondering if the potential for extra effort on an 80% reduction becomes the obstacle in fast shifts compared to a potentially less leveraged 30% allowing a faster shift due to less effort.
    Wish I could do a side by side comparison.
    TodayWasTHeDaY likes this.
  13. Apr 3, 2023 at 9:07 PM
    NashMan
    Trd has a taller shifter mine is abit shorter and I have a taller base so makes it about 80% I don't even move my elbow in the video and can shift 1st 2nd 3rd 4th with out moving my hand much. but you can run it longer but you will have to buy 1/2 round stock and the throw will increase and get lighter in throw and you can move the knuckle around for best leverage for you driving position, long armed, short armed short legs long legs ect or after market seat's
    as for shifting fast you can be alot faster on a good day for shifting what holds me back is the unresponsive drive by wire or high rpm/speed of rpm climbing were the synchros in transmission take time to line up and mostly first to second all other seam to be fast since the rpm climb is slower if you can nail the laggy throttle and inticipate it with you clutch foot and don't fully lift off the clutch it's dang fast again good day bad day for shifting fast lol
    i do have an idea for a shorter throw clutch pedale with linkage..... not a pedal stop since pedal stops don't allow full spring force of the diaphragm when you dump the clutch
    i hope this answers some of your question's I am a mechanic/fab guy by trade
  14. Apr 4, 2023 at 11:14 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    To add- HPTuner can address the rev hang. I have not experimented. I believe some rev hang is desired, just not at the factory level.
  15. Apr 4, 2023 at 11:31 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I've had the rev hang mostly deleted for a few years now and Hptuners is worth it for that alone.
    Also very interested in this shifter.
  16. Apr 4, 2023 at 1:04 PM
    TodayWasTHeDaY
    Russ
    Calgary
    @NashMan is there any wear items or maintenance other than the bushings that are the same ones Toyota uses?
  17. Apr 4, 2023 at 8:15 PM
    NashMan
    correct just oem bushings and there is nothing to ware out because there is no threading on the knuckle so if you break/stretch/strip any thing the fasteners all can be found at a local auto parts store.
  18. Apr 5, 2023 at 5:41 PM
    NashMan
    After some further research this shifter can be used on a r155 5 speed trans but I need to test hight spacer installed to see how close it is to the body of the truck. I can 3rd print a hallow spacer to test fit and then work out a very good deal a shifter for helping me
  19. Apr 5, 2023 at 7:27 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    I wish I would have seen this about 2 weeks ago. I just got a urd short shifter but I think this would work better for my situation. I'm trying to fit triple shifters in with the transmission shifter. I really like how adjustable this is. I will keep this in mind if I can't make what I have work well.
  20. Apr 7, 2023 at 7:22 PM
    NashMan
    ya I seen videos of people trying to make them fit, this was one of the reason's on making them and that they would appeal to 4x4 people as well
