No 120AC outlet on 2019 Tacoma ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Anubis325, Oct 17, 2018.
  1. Oct 17, 2018 at 6:55 PM
    Anubis325
    Anubis325 [OP] New Member
    Richard
    2019 Tacoma TRD Sport 4x2 Cement
    None yet
    Hey guys brand new to the forum, literally just received my Brand New Tacoma today. 2019 Tacoma TRD Sport 4x2 Cement. I noticed that in the trunk i did not see the 120ac outlet which i would normally see in all other Tacomas. Did 2019 change this? If you look at the brochures it shows that the TRD Sport should have this. just wanted to see if you guys got any info on this before i call the dealership. Thanks for the help and hope to learn a bunch from you guys.
  2. Oct 17, 2018 at 7:14 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    sub'd. curious to know too
  3. Oct 17, 2018 at 7:18 PM
    ATC Taco
    ATC Taco Active Member
    Justin
    18 Off Road DC MT Blue
    That would suck! I haven’t used mine yet, but God, what a great accessory to have!
  4. Oct 17, 2018 at 7:23 PM
    VegasKnights
    VegasKnights Well-Known Member
    2019 TRD Off Road 4x4 Double Cab
    Just looked in the manual. Says "if equipped" . Just picked up an off road 4x4... i thought i saw it back there... I will have to check tomorrow. :/
  5. Oct 17, 2018 at 7:26 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Probably more games with option packages to hide price increases. But they did delete the cubby so who knows.
  6. Oct 17, 2018 at 7:26 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
  7. Oct 17, 2018 at 7:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    X2
    BSFord likes this.
  8. Oct 17, 2018 at 7:30 PM
    TacoManTaco
    TacoManTaco Well-Known Member
    What??? They deleted the cubby in the bed??
    shakerhood and Vbpiper like this.
  9. Oct 17, 2018 at 9:00 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    That sucks
  10. Oct 17, 2018 at 9:19 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    :facepalm:
    Guess Toyota somehow has to pay for that extra USB port that comes with the 2019's ....
    Lawfarin likes this.
  11. Oct 17, 2018 at 11:41 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    They also deleted the even smaller cubby storage hole just above the driver side wheel well inside the bed mid 2nd Gen back around 2010ish.
    So they went from three to one storage cubby hole...what a bummer.
  12. Oct 17, 2018 at 11:50 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    That sucks, I didn't know they removed the small ones above the wheel wells. For those of us that have sleeping platforms it's great for handguns and routing pee tubes :quickdraw::bananadance:
  13. Oct 18, 2018 at 6:21 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Have a photo to share? Definitely call the dealership if you don't have it. All TRD's should.
    I don't think this is what happened to you, but this has happened before on the forum, where someone has bought an SR5 dressed up as a 'sport'. False advertising by the dealer.
  14. Oct 18, 2018 at 6:59 AM
    shakerhood
    Southern Ohio
    Those small open pockets on 2nd Gen were on both sides, my 08 had them but my 15 did not.
