No 16" rims on 6" lift
Discussion in 'Suspension' started by FLtaco, Jul 17, 2010.
  1. Jul 17, 2010 at 5:26 PM
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    I have a set of 16" rims now and was wanting to upgrade my 3" lift on truck to a 6" but have read online that you must have 17"+ rims in order to do so. Any truth behind this? Or is it only with certain lifts? Also can my 3" lift be combined with the new 6" lift?
  2. Jul 17, 2010 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, THe drop bracket lifts use a different spindle, so the larger wheel must be used.
  3. Jul 17, 2010 at 5:53 PM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    could a spacer be used to make the 16" fit?
  4. Aug 24, 2010 at 5:46 PM
    TacoIII
    Andrew
    Albuqerque
  5. Aug 24, 2010 at 5:46 PM
    TacoIII
    Andrew
    Albuqerque
    ? still wondering
  6. Aug 24, 2010 at 6:24 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    Yep 16" stock trd rim works on a Fabtech 6" with spidertrax spacers..
  7. Aug 24, 2010 at 6:27 PM
    TacoIII
    Andrew
    Albuqerque
    so im guessing itll work on a pro comp lift to??
  8. Aug 24, 2010 at 6:30 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    I heard you cant with the pro comp cause the spindles are different. ( dont quote me on that one). But i do know that the RCD DB lift will fit the 16" stockers but you will have to trim the tie rods a little.
  9. Aug 24, 2010 at 6:32 PM
    TacoIII
    Andrew
    Albuqerque
    hmmmm. well thanks for the info! maybe someone on here knows for sure
