no 4x4 08 tacoma
Discussion in 'New Members' started by old49f1, Feb 8, 2012.
  1. Feb 8, 2012 at 1:34 PM
    old49f1
    old49f1 [OP] Member
    wayne
    catawba va
    08 tacoma 4x4
    running boards,vent visors ,bug deflector,bed cover,trd seat covers trd mats,extend bed
    no 4x4 08 tacoma think its the ft.accuator.is the hose at accuator a vent hose?
  2. Feb 8, 2012 at 1:40 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Wut? and welcome to TW!
  3. Feb 8, 2012 at 1:42 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Where is catawba? Pls advise.
    Az
  4. Feb 8, 2012 at 1:42 PM
    old49f1
    old49f1 [OP] Member
    wayne
    catawba va
    08 tacoma 4x4
    light blinks in dash does not burn solid.transfer case makes a clunk when you put it in 4x4 .ft drive shaft turns with truck on lift but ft wheels dont turn
  5. Feb 8, 2012 at 1:44 PM
    old49f1
    old49f1 [OP] Member
    wayne
    catawba va
    08 tacoma 4x4
    catawba is 12 miles east of blacksburg va.(va.tech)
  6. Feb 8, 2012 at 1:56 PM
    old49f1
    old49f1 [OP] Member
    wayne
    catawba va
    08 tacoma 4x4
    is the add conector at the t-case
  7. Feb 8, 2012 at 2:03 PM
    AZBACKCOUNTRY
    Doug
    Oh cool . I like the name " catawba" way cool . Welcome to TW> :)
    Az
  8. Feb 9, 2012 at 4:25 AM
    old49f1
    old49f1 [OP] Member
    wayne
    catawba va
    08 tacoma 4x4
    ok ,checked that one ,its goog took it off axle and cleaned contacts worked one time
  9. Feb 9, 2012 at 4:36 AM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    If the breather tube has come off there is a good chance water and dirt has made its way into the actuator and corroded the contacts inside. May have to take it apart and inspect inside connections. Same happened to mine.
  10. Feb 10, 2012 at 8:45 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  11. Feb 14, 2012 at 2:21 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
