no 4x4 lock up on my 03 tacoma
Discussion in 'Technical Chat' started by SAM1944, Aug 8, 2011.
  1. Aug 8, 2011 at 5:41 PM
    SAM1944
    SAM1944 [OP] New Member
    evergreen co
    2003 tacoma 4x4
    none
    my 03 tacoma will not shift the front differental to lock it into 4x4-any clues?
  2. Aug 8, 2011 at 5:43 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Is it the t case not engaging or your ADD?
  3. Aug 8, 2011 at 5:47 PM
    SAM1944
    evergreen co
    2003 tacoma 4x4
    none
    ;i can't get my tacoma to shift the front differental into 4x4
  4. Aug 8, 2011 at 5:48 PM
    SAM1944
    evergreen co
    2003 tacoma 4x4
    none
    why won't my 03 tacoma go into 4x4?
  5. Aug 8, 2011 at 5:57 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Check your other post someone needs more information. Don't be impatient and double post when you don't get a immediate response, and welcome to TW.
    Frank
  6. Aug 8, 2011 at 6:04 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    man i have the same issues with my 05 u can check out 4x4 switch thread or big problem thread and it may help you i dont know.
  7. Aug 8, 2011 at 6:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you check your vacuum line? The actuator? The fuses?
  8. Aug 9, 2011 at 12:41 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Have a nice Day.
    This^^
  9. Aug 9, 2011 at 9:17 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The Tacoma uses an ADD (Automatic Disconnecting Differential)... which is a newer form of 'automatic locking hubs' that allows you to shift on-the-fly into H4 and not need to manually lock the front hubs (hubs permit less wear on the front driveline when you are only using 2WD).
    The ADD is activated by a vacuum line every time you go into 4WD. That vacuum line may fail. Not common, but happens.
