No A/C after fan resister replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by srspicer, Jul 29, 2017.
  1. Jul 29, 2017 at 12:45 PM
    srspicer
    srspicer [OP] Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Greetings Everyone,
    I have just completed the interior fan speed resister replacement to my 05' tacoma.
    The A/C worked before the replacement. The truck had been sitting for about a week the last time the A/C worked, before the replacement. Did the work today and no A/C. I don't hear the compressor kick on either. Checked the fuse under the hood and that was intact. I also tried the spare fuse they provide just in case. Lights on the buttons work as well.
    Any help would be great. Thanks in advance!!
  2. Jul 29, 2017 at 12:57 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why did you replace the resistor of everything was working fine? Best to tackle this situation one step at a time.
    Check for power at the blower motor with the ac on its highest setting. Also check for ground. If nothing then suspect a bad resistor. If you have power and ground it's a bad blower motor.
  3. Jul 29, 2017 at 1:02 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Yeah why replace the resistor if a/c worked ?
    outlawtacoma likes this.
  4. Jul 29, 2017 at 1:29 PM
    srspicer
    Lower Bucks PA.
    My bad! The fan only worked on High, that's why I did the replacement. Sorry for the confusion.
    Also the check engine light is now on. Plugged the reader in and got the following;
    PO455, evaporative emission leak, incorrect purge flow. I'm going to have to look that up for further action.
    Any comments welcome!
  5. Jul 29, 2017 at 1:44 PM
    Bebop
    Nick
    If the blower only worked on high and now you got nothing at all. I would suspect a bad resistor but do your due diligence and check for power first.
    wilcam47 likes this.
  6. Jul 29, 2017 at 1:48 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    put the old resistor back in and see what happens.
  7. Jul 29, 2017 at 3:35 PM
    srspicer
    Lower Bucks PA.
    Fan works on all speeds now. No A/C after the resister fix.
  8. Jul 29, 2017 at 4:18 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Probably popped the clutch fuse.
  9. Jul 29, 2017 at 4:21 PM
    srspicer
    Lower Bucks PA.
    Which fuse is the clutch fuse? The A/C fuse under the hood was fine. Thanx
  10. Jul 30, 2017 at 8:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IG1 No2 10 Amp Fuse is what feeds the Magnetic Clutch Relay.
  11. Aug 2, 2017 at 10:29 AM
    srspicer
    Lower Bucks PA.
    No of my 10, 15, 20 or 25 amp fuses are bad. Probably not enough coolant in the system. Thanks for the help!!
  12. Aug 2, 2017 at 11:12 AM
    Bebop
    Nick
    What? Coolant or freon?
  13. Aug 2, 2017 at 11:13 AM
    srspicer
    Lower Bucks PA.
    I don't think we use freon any more, so just plain coolant covers it for me.
  14. Aug 2, 2017 at 12:30 PM
    Bebop
    Nick
    Your ac system uses freon or refrigerant. Your engine cooling system uses coolant or antifreeze. Still 2 completely different things
    File IFR and wilcam47 like this.
  15. Aug 2, 2017 at 12:56 PM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    the confusing of terms in this thread hurts my brain...
    blower motors and a/c not working are different things. freon and coolant are different things (like bebop said)
    the refrigerant (aka freon) in your truck is R134a. just an fyi don't call it coolant or people in auto shops will laugh at you. As for you problem, check the fuse first of course, if that's good then check the magnetic clutch relay. if thats getting triggered properly and has power, then check power and ground at the clutch connector.
  16. Aug 2, 2017 at 12:58 PM
    srspicer
    Lower Bucks PA.
    I understand that. Since the thread talks about A/C issues, one would assume if I use the term 'coolant' it refers to the A/C system.
  17. Aug 2, 2017 at 1:02 PM
    Bebop
    Nick
    The term coolant refers to antifreeze. If you went into an auto parts store and asked for coolant, they would hand you a gallon of antifreeze. Do yourself a favor and get your ac system looked at by a professional. An ac system is not meant to be messed with by your average joe
  18. Aug 2, 2017 at 1:13 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you damage the evaporator while under the dash? Does the condenser in the front have a leak? Is the pressure switch located on the evaporator plugged in?
    Lots of questions here need to be answered before we can move forward.
  19. Aug 2, 2017 at 1:25 PM
    srspicer
    Lower Bucks PA.
    Done all of the checks, already taking it to my mechanic to check the system, who BTW, said we need to check the coolant pressure in the system. I understand its confusing, can we move on please and continue with the good advice that I greatly appreciate?
  20. Aug 2, 2017 at 1:32 PM
    koditten
    Kirk
    Central Michigan
    No, I don't think so.
    Remember, this thread just became a record. Anyone that does a search may come upon this thread. We want people know the correct terms and try to limit information that will only confuse newer people.
    I am glad you are taking the truck to a pro, I was getting the impression that you need to work on your skills when it comes or wrenching on vehicles.
    It may have annoyed you that you were corrected and could not get a good answer, but it is part of learning how these sites work.
    Please feel free to ask questions at any time, just include that you are in the learning phase, but are a good listener.
    Welcome to the show. This really is a great site, just need to know how to work it.
    Kirk
    File IFR likes this.
