No A/C after fan resister replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by srspicer, Jul 29, 2017.
  1. Aug 2, 2017 at 2:04 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    If your mechanic is calling refrigerant coolant it's time to find a new mechanic.
  2. Aug 2, 2017 at 3:28 PM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    Agreed. If you took a Dodge Cummins to a gas station and asked for gasoline, then yes you would get a type of fuel, but it certainly won't be right for what you need. It might seem trivial, but it's a distinct difference and just confuses things for no reason. It's not coolant.
    Back to your problem, you have been given lots of things to check. Personally I would start at the relay. If its getting signaled then you know it's trying to turn on the system. Then it's down to where is the power being lost. or a ground or the clutch could itself. If it's not being signaled, then you could have lost your charge, or the pressure sensor went out.
  3. Aug 2, 2017 at 3:36 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  4. Aug 2, 2017 at 5:40 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I'm not a dick, I'm/we're just guiding you in the right direction.
  5. Aug 2, 2017 at 5:41 PM
    File IFR
    Central MA
    Did you remove the HVAC panel on the console when you replaced the resistor?... Maybe you have the control unplugged.
