No A/C at high speeds? PLEASE HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redhed, May 6, 2010.
  1. May 6, 2010 at 7:08 PM
    Redhed
    Redhed [OP] Motorboatin' SOB
    Paul
    Flagstaff, AZ
    06 Prerunner BSP
    Polk Audio components, Rammat sound deadening & Ensolite, blacked out emblems, color matched grill, rhinolined rear bumper, shorty antenna, nerf bars, black Toyota trail edition rims, Sockmonkey vinyl, retrofit overhead temp/compass, JDM Altezza tailights, JDM Black Crystal headlights, Hella Black Magic driving lights, 20" dual row LED light bar.
    OKay, I've been searching on here for some answers and so far haven't found anything that covers what I'm experiencing. My A/C works fine until I hit the highway. The blower works fine, just no cold A/C on the highway? I'm really puzzled on this one? Any ideas? I've got a 2006 Prerunner Doublecab with 70,000 miles and I'm hoping to save a trip to the dealer. :(
    Thanks.
  2. May 6, 2010 at 7:15 PM
    Bu11etWhisperer
    Bu11etWhisperer My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    Try having the system recharged with Freon. This might sound stupid but then again it may fix the issue.
  3. May 7, 2010 at 8:23 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Just a thought but many vehicles has a disable circuit for wide open throttle (WOT) operations. Could be something along those lines.
  4. May 7, 2010 at 8:34 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Mine has done the same thing for a couple years..............I will get on the frwy and hit 45 and lose it......so I will slow down to about 10 and get it back and usually don't lose it......I think it might have something to do with a lose belt or the clutch is messed up.........I like you have posted this problem before on many sites and no one seems to know the problem...............good luck..............I'm just going to buy another truck....72,000 miles as well
  5. May 7, 2010 at 8:35 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Either you are too low on refrigerant or the system is overfilled either way you need to double check that. It will require the use of a manifold gauge set and a DVOM. Also excessive air gap on the compressor clutch may cause the disengagement.
  6. May 7, 2010 at 8:44 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    You definetly need to have your a/c system inspected. You may have a leak or may just be low on R134-A (technically it's not freon R-12 is called freon). Or your compressor may be going out. You could have a faulty high pressure switch or your fan clutch could be weak or..... There are many things that could be causing your problem. And A/C work is not something you should do at home (unless you are a certified technician). Take it to a trusted mechanic and have them diagnose it for you. Just my .02
  7. May 16, 2010 at 6:22 PM
    Redhed
    Paul
    Flagstaff, AZ
    06 Prerunner BSP
    Thanks, weird but this did start after I installed my stereo ie, had my battery diconnected for a while. Since I posted this I haven't had a problem. If it starts again I'll try what you said. Thanks again to all who replied.:)
  8. May 16, 2010 at 7:48 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    if you unplugged the heater controls, make sure when you plugged them back in none of the pins pushed out of the connectors slightly making it an intermittent contact with the control head
  9. May 16, 2010 at 8:49 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Same here. I did some work on my fuse box and the battery was disconnected for a while, when everything was back up running the A/C didn't work for a couple hours. The guy at the shop works on a lot of Tacomas and said it was normal, I thought it was BS but I guess he's right. It hasn't happened again.
