No a/c in florida!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06yoter, Jul 5, 2009.
  1. Jul 5, 2009 at 12:16 PM
    06yoter
    06yoter [OP] Active Member
    Tampa/ Plant City, Florida
    06 Prerunner TRD Sport
    Doug Thorley long tubes, flowmasters, URD TCAI, custom dent in the bed from a fence
    so i woke up this morning and went outside here in florida, turned on my truck, looked up at my compass/ outside temperature gauge where it said 101 degrees in my black tacoma, turned my a/c on high and NOTHING CAME OUT! i left it running a few minutes and opened up my hood and one of lines running to the passenger side firewall had a thick coat of ice on it so i just shut the whole unit off. WHAT DO I DO?? ITS HOT AS HELL HERE IN FL.! thnks for yalls help -chris
  2. Jul 5, 2009 at 12:19 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    sounds like the compressor froze up because it is super humid there probably. I have never heard of this happening in a car. I would just let it thaw and see if it works then. or drive it a little bit and then turn it on, it should thaw quickly.
  3. Jul 5, 2009 at 12:19 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    I'd get it fixed ASAP
  4. Jul 5, 2009 at 12:25 PM
    06yoter
    yea i let it thaw and it seems the compressor is kicking on because i can hear it idle up when i turn the a/c on but nothing comes out. is there i fuse for the blower motor possibly???
  5. Jul 5, 2009 at 3:50 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Did you get this fixed? If so what caused it?
  6. Jul 5, 2009 at 3:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    101 Hot as hell??
    :popcorn:
  7. Jul 5, 2009 at 6:50 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    There should be a fuse for it. So your getting no air at all coming out and you can here the compressor kicking in?
  8. Jul 5, 2009 at 7:49 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    101 degrees That's COOL....:D It's only 113 here today...
    As for your a/c not working and it's freezing up.
    Did the cabin air even start to blow, any air? If not I'd look at the fan for in the cab air. If no air is moving across the coils the evap will freeze up and that CAN destroy a compressor. (First)
    If the air is flowing in side then you might be low on freon (gas). Have it checked and find where it leak out and fix it. (Second)
    Or it could be something else, have a tech check it out.
    Yuma Taco,
  9. Jul 5, 2009 at 8:01 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    With 95.5% humidity it is. :)
  10. Jul 5, 2009 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Been there plenty of times. Hot, yes. Hell, no.
  11. Jul 6, 2009 at 10:26 AM
    fishshooter
    Northwest Florida
    Stock
    True, it's not Arizona hot. When you start bumping 120's, it's hell, regardless of the humidity.
  12. Jul 28, 2009 at 1:23 PM
    06yoter
    yea the humidity is what kills the heat here. but i got it fixed. i took it to a guy and felt like an idiot because all he did was reach up under the passenger dash and hit it and it kicked on. i guess the wires for the blower motor were loose or its going out. im not to worried about it cause it hasnt messed up since.
  13. Jul 28, 2009 at 2:53 PM
    rmb_crew
    glad you got it taken care of man. Its not going to get any cooler here.
