No a/c or recirc , no heat control, no function change control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brogie, May 13, 2024.
  1. May 13, 2024 at 1:23 PM
    Brogie
    Brogie [OP] Well-Known Member
    Mark
    Columbus, OH
    2014 4wd standard cab silver sky
    Okay folks, I installed a new head unit and subwoofer to my truck (2014 4wd base, standard cab, 107000 mi). I removed the hvac control and set it aside then removed the radio and dash section with vents.. During the radio installation no wires were cut or tampered with, I used a converter harness so it was all plug and play. Reassembled dash, plugged in hvac control and popped it back in. The entire time the hvac harness wasn't touched, it just hung out of the way until needed.
    Radio and sub worked fine. Blower fan control works fine, the temp control knob has no effect, the vent setting control knob has no effect, it is presently stuck in defrost/floor mode and the compressor is working. A/C and Recirc buttons not functioning. All fuses check fine with meter, swapped heat relay with no change.
    I am lost after checking the obvious and easy, also popped out control panel and reseated connector. Is it possible or likely that the control panel went south on me for no reason. I am open to any and all suggestions. TIA
  2. May 13, 2024 at 4:20 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. May 13, 2024 at 4:30 PM
    Brogie
    Mark
    Columbus, OH
    I'll check the fuse again Is there a schematic somewhere that shows what the power should be at the terminals in the plug to the hvac control? thanks
  4. May 13, 2024 at 4:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Here's the wiring diagram, the link I posted above has testing for the actuators.
  5. May 13, 2024 at 4:57 PM
    Brogie
    Mark
    Columbus, OH
    Thanks. I'll recheck stuff tomorrow and see what I get.
  6. May 14, 2024 at 9:37 AM
    Brogie
    Mark
    Columbus, OH
    Thanks Dm93. Mystery solved, a harness that didn't get plugged in properly.
    ToyoTaco25 and Dm93 like this.
  7. Dec 1, 2024 at 6:20 AM
    HecticHornet295
    HecticHornet295 Member
    Erika
    06 speedway blue Tacoma
    Rockergaurd, 3 inch lift, tundra front bumper, new LED tail lights, exhaust, add a leaf, cold air intake with k&n reusable filter 7 inch light bar in hood, 20 inch light bar on truck cap. New stereo deck install
    Good day. I've recently inherited an 06 tacoma from one of the members on here. All other work done set aside. After installing a new double din unit. I have no heat, no power to the whole system. I never touched the control module it stayed firmly planted in the dash. I've checked the obvious. Started with the blower found it to be nonfunctional after connecting to 12v power. I have a friend in the junkyard business so I got a new to me blower, check that it operated on 12v power which it did. Checked all the related fuses and relays in both fuse panels and all. Found that the heater relay was stuck In the on position replaced still nothing. Texted the resistor for continuity to find it had none, replaced that still nothing. I've lived in shops all my life and am more than educated on diagnostics I'm at a loss. Any suggestions. It's mighty cold driving ti work in the winter with the windows down.
  8. Dec 1, 2024 at 7:50 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Start with this: If not done yet,I would try again unplugging and reconnecting every one of the connectors: all of them back there a few times (more than once: even the ones that you didn't disturb) This will clean the contacts that until now, likely haven't been disturbed for almost 20 years. Make sure when you re-connect them they click firmly into place. Be gentle: those are old plastics and wires.
  9. Dec 1, 2024 at 8:50 AM
    HecticHornet295
    Erika
    I have done that a few times.i had the while bottom of the dash apart tracing wires. I found that the red wire that supplies power tk the unit had corroded so I cleaned it up and reconnected it, also found a similar situation with the green wire for the blower rmthat meets at the interior fuse panel that I also fixed seemed like everything failed at once.
  10. Dec 1, 2024 at 10:43 AM
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    Erika, I'm going to copy and paste the post onto the build thread, and see if any traction can be gained there, or at least keep the chaos contained..
    https://www.tacomaworld.com/threads/the-scenic-route.535473/page-1
    Might take me a while.
    *fixed.. use of force, threats, and superglue.. pulled/ followed the diagnostic manual posted above, removed/inspected each connection, and, today at least, found the hvac control module to be out of spec.. Some bending of the spider actuator behind the fan speed controller restored continuity.. Feel like something got broken during early diagnostics, original problem was fixed by replacing components, and new problem was fixed by persistent tinkering. *
    thanks @Dm93 these resources are amazing, and a lot of work to upload, preciate ya!
    Dm93 likes this.
