No AC after Waterpump/thermostat install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnders, Sep 24, 2017.
  1. Sep 24, 2017 at 4:40 PM
    Johnders
    Johnders [OP] Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    Hey Guys
    I recently install a new water pump and thermostat in my 2010 2.7l. I went to use the AC today and it blew warm air. It worked before the install but I admit I hadn't used in in a while.(probably a month) Not sure if this is coincidence or related. I was pretty careful to make sure everything got put back together. Anyone have any ideas what I could have missed or not plugged back in to cause this?
    I appreciate the help!
  2. Sep 24, 2017 at 4:46 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Make sure you didn't damage the electrical connection on the compressor
  3. Sep 24, 2017 at 7:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check to see if the clutch is engaging when you turn on the AC. If yes you may just be a little low of refrigerant. If no you may be very low of refrigerant and the pressure switch is not allowing the clutch to engage.
    Check the wire harness going to the AC Compressor clutch to ensure that it isn't damaged or unplugged.
    Check The 10 Amp A/C Fuse and the 10 Amp IG1 No.2 Fuse.
