no acceleration past 70mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Emtmeyer, Apr 5, 2016.
  1. Apr 5, 2016 at 4:39 PM
    Emtmeyer
    Emtmeyer [OP] Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    its decent in first and second, power starts dropping off in 3rd and up.
  2. Apr 5, 2016 at 4:39 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    this as well
  3. Apr 5, 2016 at 4:41 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    brakes are fine, im going to get a compression test soon, sensors all seem to be ok that i can read on my UG. could the speedo being so far off limit the engine?
  4. Apr 5, 2016 at 4:46 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Are you tracking your speed off GPS?
  5. Apr 5, 2016 at 4:48 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    off my UG that was calculated by gps
  6. Apr 5, 2016 at 4:49 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    possible fuel pressure regulator is on the fritz?
  7. Apr 5, 2016 at 4:49 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    No clue, the 4cyl aren't fast by any means. I am not an expert on gears, but I am over geared on 35's with 4.88s. With you running 33's, could it just be that you need a taller tire?
  8. Apr 5, 2016 at 4:52 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    i was wondering this as well, would the additional travel of the tire put me higher in speed and lower rpms for a broader range of usability.
    would that cause the lack in power?
  9. Apr 5, 2016 at 4:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you play with the gear calculator I linked in post #18?
    Miles on the truck would be interesting too? And the 'life it's led'. Might reinforce the pointing to compression issues.
  10. Apr 5, 2016 at 5:00 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    125k, second owner. first owner was a little old man that babied the truck. i keep it tip top always.
  11. Apr 5, 2016 at 6:04 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    in short, yes. that regulator may not be keeping up with the fuel demands at that speed and load. you would really need a gauge on the fuel line to see if the necessary pressure exists at that point.
    Old School and 12TRDTacoma like this.
  12. Apr 5, 2016 at 6:06 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    lol ok ill swap the regulator as well. its getting to the point that im about to start browsing LS1 engines because itll be cheaper than fixing this and ill get insane power. MAF was thoroughly cleaned as well.
  13. Apr 5, 2016 at 6:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    How big are these hills & how strong head winds ??.....
  14. Apr 5, 2016 at 6:11 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Was gonna say, it IS a 4cyl...
  15. Apr 5, 2016 at 6:11 PM
    #35
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    lol not very. maybe 10-15 mph wind and pretty gradual mountain passes
  16. Apr 5, 2016 at 6:12 PM
    #36
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    yeah but my ex gfs car was the same engine in a camry and it hauled ass pretty well and never struggled on hills. same exact road too.
  17. Apr 5, 2016 at 6:15 PM
    #37
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    i don't want to encourage just slinging parts at a problem.... do the compression test. see if it is feasible to get a fuel test gauge and troubleshoot with that. lastly, you may have an issue with the wiring for the fuelpump. you can try a simple relay swap to see if the relay is causing extra resistance in the power wire. this could cause a voltage/amperage issue.
  18. Apr 5, 2016 at 6:17 PM
    #38
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    ill try that, im going to be beyond pissed if a $5 relay has been my issue this whole time.
  19. Apr 5, 2016 at 6:18 PM
    #39
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    URD sells a fuel rail tap also
  20. Apr 5, 2016 at 6:18 PM
    #40
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Good advice, & I'd think it would be lit up like a christmas tree with codes thrown with that kind of decreased performance..
