No alignment needed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cooktaco, Apr 9, 2012.
  1. Apr 9, 2012 at 2:46 PM
    cooktaco
    cooktaco [OP] Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    Got the rear spring TSB done and put on a set of Bilsteins 5100's set at 1.75 to level the front. Everything I read here stressed a front end alignment is needed. Took it to the shop and they said it was perfect, no alignment needed. Very reputable shop I have used for years and they didn't charge me for putting it on the rack. Can this be right, or should I consider taking it to another shop for a second opinion?
  2. Apr 9, 2012 at 4:27 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Was the alignment done at dealer as part of the TSB? If so, perhaps the 1.75" wasn't enough to take it out of spec. When I had the TSB done, I supplied the dealer with the 5100's and had them set at 1.75", I know they performed the TSB required alignment but I'm not sure how far out of spec it was, if at all...
  3. Apr 9, 2012 at 4:42 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    So they installed 5100's on the front for you? I have been considering the 5100's and TSB so I was thinking maybe I could install the 5100's on the front just before taking it in for the rear leaf TSB so I wouldn't have to pay for an alignment. But I didn't figure they'd go for it.
  4. Apr 9, 2012 at 5:37 PM
    cooktaco
    Northern California
    11 Dbl. cab TRD 4x4
    Sorry-wasn't real clear in my first post. Dealer did the spring TSB and alignment. A week later I installed the Bilsteins in the front @ 1.75 and took it in to have the front end aligned. Shop said it was all good, didn't need an alignment. No reason not to believe them, but almost everything I have read on TW stressed getting a front alignment after Billy install.
  5. Apr 9, 2012 at 5:39 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Get the printout of the alignment if you are worried about it.
  6. Apr 9, 2012 at 5:51 PM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    i just installed 5100s at 1.75, and an aal in back. i took it to my local shop, and they adjusted toe-in .4 on passenger side, that was all. pretty slick
  7. Apr 9, 2012 at 5:59 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Always request a spec sheet printout when getting a alignment.
  8. Apr 9, 2012 at 6:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It may well be in spec with no worries. Gotta get it checked-Doesn't mean it'll need to be changed.
