no alternator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alansue, Jun 14, 2020.
  1. Jun 14, 2020 at 2:03 PM
    Alansue
    Alansue [OP] Member
    2005 Tacoma TRD Sport Crew Cab
    new frame installed
    Anybody have an idea of how far I could drive in daylight with alternator that is not working and fully charged battery? No headlights either. Thanks
  2. Jun 14, 2020 at 2:22 PM
    Muddinfun
    Muddinfun Well-Known Member
    Reserve capacity is the number of minutes a battery can provide a 25 amp draw until it drops to 10.5 volts. In theory, that’s the number of minutes that you can drive with only the necessities running. There will be a huge difference between a brand new 27F and a 7 year old 24F.
    Personally, I wouldn’t push it more than 1 hour on a fairly new fully charged battery. This is also assuming that the serpentine belt is still there and turning everything else.
    wilcam47 and b_r_o like this.
  3. Jun 14, 2020 at 2:54 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    To the end of your driveway.
  4. Jun 14, 2020 at 2:55 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    With everything off that you don’t need on. I’ve seen trucks go 20-30 miles. All depends on the heath of the battery. But be warned unless it’s a deep cycle, you’ll likely end up killing the battery
    wilcam47 and gotoman1969 like this.
  5. Jun 14, 2020 at 3:01 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There is a lot of things going on fuel pumps, signal/brake lights, engine controls, radio memory etc it's a crapshoot end of the drive probably isn't too far off the mark!
  6. Jun 14, 2020 at 3:10 PM
    lynlan1819
    Tacoma
    Lifted
    O.P. can go drive anywhere,and when his truck quits he can then pay an expensive tow bill PLUS buy a new alternator.
    wilcam47 likes this.
  7. Jun 14, 2020 at 4:41 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I got about 30km on mine till every dash light came on and Speedo went crazy. Good luck!
  8. Jun 14, 2020 at 5:28 PM
    Bishop84
    Bishop84 Well-Known Member
    If its the same battery that was used during the alternators death it is likely in poor state of health.
    Even with it at 12.6v its unlikely to last more than 10 minutes.
    whatstcp and wilcam47 like this.
  9. Jun 14, 2020 at 7:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The best answer is Don't do it.
    CurtB, 6 gearT444E, whatstcp and 2 others like this.
  10. Jun 14, 2020 at 7:39 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    While there is Only one way to find out, I wouldn’t try it.
  11. Jun 14, 2020 at 7:46 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Not very far.... maybe 10 ft
  12. Jun 14, 2020 at 7:47 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    You will make it to the end of the drive
  13. Jun 14, 2020 at 8:36 PM
    Muddinfun
    It depends on the circumstances. If I was an hour away from home and the alternator died, I would make sure the serpentine belt was still there, jump on the freeway and haul ass for home. If I didn't make it, I would go to plan B. Have a friend bring out a fully charged battery or have a friend come out and hook up jumper cables for an hour and then follow me home. If the alternator died in my driveway, I wouldn't take it for a scenic drive out of town. I might take it to the store to get beer though.
    robssol and whatstcp like this.
  14. Jun 14, 2020 at 8:44 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    What ever happened to men with trailers that help a friend out?
  15. Jun 14, 2020 at 8:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    We did this once with a 1990 suburban. Alternator started making noise, then it quit charging. It went about 2 hours home, then the bearings in the alternator completely gave up, sliced the serpentine belt in half the long way, and then caught fire.
    That was the day I learned that there are alternator cores that the store won't take. If the fan on the front has dug into the housing and there are chunks of aluminum everywhere, thats a pretty good sign.
    I wouldn't do it unless it was a very short trip. Vehicles these days are way more electrically hungry anyway.
  16. Jun 14, 2020 at 8:51 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Just far enough away to be inconvient or close to a parts store... give or take 1hr walk
    VirusCage and ColoradoTJ like this.
  17. Jun 14, 2020 at 9:57 PM
    ColoradoTJ
    Colorado
    True story!
    wilcam47[QUOTED] likes this.
  18. Jun 15, 2020 at 1:29 AM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Lol maybe you should tow. AAa membership is not that expensive
  19. Jun 15, 2020 at 8:16 PM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    As a general rule of thumb if the charge light comes on, and you have a good battery expect 15 mins of run time, depending on what goes wrong in the alternator, it can act like a huge load as the voltage reg, full fields, but nothing leaves the alternator, alternator gets hot and acts like a toaster, sucking the battery down in mins, other times it can last hours as its not trying to energize the field.
    so depending on how the alt fails is the deciding factor on how long it lasts. unplugging the field wires on the alternator helps extend run time
  20. Jun 15, 2020 at 8:39 PM
    kingk0ng
    11 TRD OR AC
    just a few things.
    Possible electrical fire also.
