No backlights for speedo, engine temp, and fuel gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rep15, Sep 6, 2024.
  1. Sep 6, 2024 at 11:52 AM
    Rep15
    Rep15 [OP] Member
    Tumwater, Wa
    2005 red Tacoma TRD
    I’ve changed my backlight and odometer OEM leds with blue leds. The odometer lights up but none of the backlights come on. What circuit are the cluster back lights on.
    The warning lights work.
  2. Sep 6, 2024 at 12:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The tail lamp circuit.
    Check your tail lamp fuse.
    The tail/head lights have to be on to check it.
    Jimmyh likes this.
  3. Sep 6, 2024 at 12:28 PM
    Rep15
    Rep15 [OP] Member
    Tumwater, Wa
    2005 red Tacoma TRD
    Fuse is good and tail lights work.
  4. Sep 6, 2024 at 12:45 PM
    TnShooter
    Deogee
    STOCK
    Then you need to check powers and ground at the meter connector.
    Pin 40 (green wire) on the meter connector is power.
    Pin 2 is Whit/Black is Ground. But it has to be good if the warning lights work.
    There is also the the 7.5A ECU B fuse. If the Door open light comes on. That fuse is good. Easy check.
    Then there is the Gauges Fuse. But again, it power the warning lights. And you say they work. So it has to be good.
    But you can check those fuse if you want.....
    I'd start at pin 40 Green wire. If it has power, then there's a a problem with the circuitry inside the meter.
  5. Sep 16, 2024 at 1:24 PM
    Rep15
    Rep15 [OP] Member
    Tumwater, Wa
    2005 red Tacoma TRD
    Thanks for the information. I checked pin 40 and it had the proper power. I'm sending it off for repair.
