No blinkers, reverse lights, Shifter locked, and more!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bigboyboo, Jan 18, 2020.
  1. Jan 18, 2020 at 10:26 PM
    Bigboyboo
    Bigboyboo [OP] Member
    2009 Toyota Tacoma
    I did check the battery terminals when I had the ground side unhooked and they looked fine. It might be worth disconnecting and cleaning them both just to guarantee that it is excluded from my possible cause, but I didn’t see any corrosion.
  2. Jan 18, 2020 at 10:27 PM
    Muddinfun
    Muddinfun Well-Known Member
    After looking at the schematics, it makes perfect sense that the brake lights work but the shift lock does not. Like I mentioned, IG1 feeds the shift lock control ECU. It does not feed the brake light switch. All things point to the IG1 circuit. Make absolutely 100% sure you have voltage on both sides of IG1. After that, you're going to have to trace out why the power is not getting to all the circuits. I have the schematics, but there's pages and pages and pages of them. Here's what I can tell you. The wires that exit the under dash fuse box that feed to the shift lock ECU and the AC amplifier are all pink and they exit through connectors on the back side of the fuse box. (Difficult/impossible to get at) The turn signal flasher is also plugged into the back side of the fuse box on non DRL trucks. On DRL trucks, there's a 3 way harness that plugs into the back side of the fusebox. Also a pink wire.
    JC15Taco and hemitruk like this.
  3. Jan 18, 2020 at 10:53 PM
    Myrtle Beach Taco
    Myrtle Beach Taco Member
    Myrtle Beach
    12 currently stock
    Back in 2015 I had an issue with several electrical components on my 2012 Tacoma. Directionals didn't work,and several other issues I can't remember. Turned out it was a Body Control Module. I wound up bringing it to the dealer for repairs. My vehicle was out of warranty by that time but the dealer covered it as a good will gesture. I remember he told me it was an expensive repair
  4. Jan 18, 2020 at 11:05 PM
    Muddinfun
    Since the underdash fusebox is the body control ECU, that may very well be the OP’s problem.
  5. Jan 19, 2020 at 10:03 AM
    caribe makaira
    Caribbean, Puerto Rico
  6. Jan 19, 2020 at 3:26 PM
    Bigboyboo
    2009 Toyota Tacoma
    Thanks you caribe makaira. If this is image is the case then I’m showing issues across both circuits. That seems that it would cause more issues than I have if the fuses were blown.
    Also, my IG1 fuse is a 15amp.
    Muddinfun, you said the fuse box is the body of the ECU. Is the ECU inside the fuse box case?
  7. Jan 19, 2020 at 3:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    It was once for me. Replaced it with one from a pick and pull and that took care of it. I had different symptoms though
  8. Jan 19, 2020 at 3:34 PM
    Muddinfun
    Therein lies the problem. You are testing the wrong fuse. IGN is 15A
    IG1 is 10A
  9. Jan 19, 2020 at 3:51 PM
    Muddinfun
  10. Jan 19, 2020 at 4:17 PM
    caribe makaira
    20tacoma17 and Muddinfun like this.
  11. Jan 19, 2020 at 4:33 PM
    Bigboyboo
    2009 Toyota Tacoma
    Oh my!! As terrible as it would be, because that would make me an idiot, I sure hope this is the case!
    Excited to get home and find out.
    JimIowa and 20tacoma17 like this.
  12. Jan 19, 2020 at 4:35 PM
    caribe makaira
    Still need to find out why the fuse did its job...:burp:
    b_r_o and 20tacoma17 like this.
  13. Jan 19, 2020 at 10:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check all the exterior bulbs and sockets. Are the bulbs correct, like dual filament where there's supposed to be dual filament? Any sockets melted?
  14. Jan 19, 2020 at 11:38 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If that fuse blew and like my 09 those DRL sockets and plastic bulb bases get burned so every year I change the bulbs out before they disintegrate. Look there. Easy to pull out and see.
  15. Jan 20, 2020 at 10:51 AM
    #35
    Bigboyboo
    2009 Toyota Tacoma
    Sure enough you guys were right. It blew the IG1 fuse. After getting over my failure, I’m here laughing and thankful for all of your help. But what I still do not know is why the fuse blew in the first place.
    I pulled my trailer wiring plug apart at the 7 pin connector and realized all of the wires were pulled out of the socket except the red power wire. My theory is that maybe the harness got pulled on somehow in transport and pulled the wires out of the sockets causing a short and blowing the fuse. Could anyone agree that this could have been the cause?
    The truck was fine when it left the house and after filling with gas at the gas station that when the problem started. When you try to roll away and your truck doesn’t go into gear you know you have a problem.
  16. Jan 20, 2020 at 10:57 AM
    #36
    Muddinfun
    LOL! Glad you found out what’s going on and admitted it. I’ll look at my schematics in a bit and see if there’s anything in the trailer wiring that could blow IG1.
    20tacoma17 likes this.
  17. Jan 20, 2020 at 11:17 AM
    #37
    Muddinfun
    A problem in the backup light wiring would definitely blow the IG1 fuse, and there is a back up terminal in the 7 way trailer connector. So, I'm guessing it went like this. You pulled into the gas station, had to jockey once or twice to get lined up to the pump. When you put it in reverse to reposition, it blew the fuse. Then you put it in park and shut it off. When you tried to go, that's when you realized that there was a problem. I'm also speculating that you underestimated the amount of slack needed in the trailer wiring to make a sharp right turn.
    Ig1 also feeds the turn signal flasher, but there's also a 15A trn/haz fuse that feeds the flasher, so I'm guessing the IG1 feed to the flasher is just a signal and not a current carrying feed.
    Lesson for the day. If you can't get it out of park, check IG1. If you find it blown, check the 7 way trailer connector.
    JimIowa and b_r_o like this.
  18. Jan 20, 2020 at 12:00 PM
    #38
    caribe makaira
    Muddinfun[QUOTED] and 20tacoma17 like this.
  19. Jan 20, 2020 at 12:26 PM
    #39
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    :annoyed:
    Glad you found it . As seen in my quote I was a bigger dummy lol. I caused the problem . Posted because you SAID you checked ALL the fuses but I know sometimes when frustrated for get some details gets left out ( ME) lol
    For me could feel the stress flowing out of my body when I realized how dumb I was:facepalm::frusty: :D
    Muddinfun likes this.
  20. Nov 2, 2022 at 7:50 PM
    #40
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    Came across this thread while trying to figure out why the hell out of nowhere my SRS light is on, no reverse lights or camera, no AC or recirculation.
    I just installed an aftermarket rear bumper and new factory hitch. After wiring up the driverside bumper auxiliary light (spliced into the reverse lights) I checked it by turning the key on and shifting into reverse, success), hook up the passenger side light, go to check to make sure it works and this is when I start losing it (lots of highly stressful things going on in my life at the moment and this pushed me over the edge). I begin to check fuses and relays, nothing. So I cleaned up my tools and locked the truck up. Disconnected the battery thinking it may need to be reset (I notice my terminals are corroded pretty badly, I'll clean and check them out in the morning). I also remember I might have pulled on the rear wiring harness when I was tightening the bumper bolts so I'll check all of that out in the morning. I'm hoping it's something simple like a fuse. Also just noticed there's condensation on the inside of the passenger bumper light so I'll disconnect that light as well since everything worked and was fine before hooking that light up. Fingers crossed.
