no brake lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by norfolkpest, Jan 31, 2016.
  1. Jan 31, 2016 at 11:30 AM
    norfolkpest
    norfolkpest [OP] Member
    02 tacoma manual
    i have no brake lights. I have taillights, backups, turn signals but no brake. I've replaced fuses, bulbs and stoplight switch and still nothing. any ideas?
  2. Jan 31, 2016 at 1:38 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    get a circuit tester and start poking. get a stick to push the pedal down and keep it engaged while you poke and prod around all your wires to see if where youre not getting power when you should.
  3. Jan 31, 2016 at 1:40 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Probably either a wire backed out of the fuse plug or corroded plug somewhere
    Fenwick1993 likes this.
  4. Jan 31, 2016 at 2:36 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Double-check the 'STOP' fuse in the fuse box under the hood. Maybe there is a short, and it blows every time you test it.
  5. Feb 1, 2016 at 7:04 AM
    norfolkpest
    02 tacoma manual
    fuse under hood ok, stop fuse under dash blows every time I step on the pedal. being new to diy repair, where do I go from here.
  6. Feb 1, 2016 at 7:17 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Sounds like you might have a short somewhere. I would try to get ahold of a circuit tester.
    I see your username says Norfolk- is that Norfolk, as in Norfolk, VA?
  7. Feb 1, 2016 at 8:12 AM
    tan4x4
    Rick
    Folsom, CA
    Are you sure about the 'stop fuse under dash' ? My FSM does not show an additional fuse for the brake-light circuit. I checked a 2003 FSM as well, and it does not show an 'under dash' fuse for brake lights.
  8. Feb 1, 2016 at 8:24 AM
    norfolkpest
    02 tacoma manual
    Norfolk MA
  9. Feb 1, 2016 at 8:27 AM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    Darn, I was hoping I'd stumbled across a local!
  10. Feb 1, 2016 at 8:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the ground wire from the taillights is secure to the frame somewhere around the rear of the truck.
  11. Feb 1, 2016 at 8:32 AM
    norfolkpest
    02 tacoma manual
    fuse #26 under dash, stop lights, high mounted stop light, cruise control, anti-lock brakes,etc.
  12. Feb 1, 2016 at 8:55 AM
    CodeSeven
    Serge.
    Coachella Valley
    remove all 3 of your stoplight assemblies and look for freyed wiring. Somewhere there is an exposed positive wire for the brakws that is shorting/grounding out and causing the fuse to blow. If you find none, trace the wiring to thw cab, looking for a freyed wire.
  13. Feb 1, 2016 at 9:01 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    ^^^^^^^^^^^^^^^^^^^^^^ What he said, for sure.
  14. Feb 1, 2016 at 9:01 AM
    norfolkpest
    02 tacoma manual
    brake lights fixed, now if I could figure out the rest..........
  15. Feb 1, 2016 at 9:10 AM
    CodeSeven
    Serge.
    Coachella Valley
    What do you mean theyre fixed? What did you do to fix them? And what is "the rest"?
  16. Feb 1, 2016 at 9:31 AM
    norfolkpest
    02 tacoma manual
    I was poking around trying to find a short. don't know how I didn't see it before but it looks as if the previous owner had a cap and instead of unplugging it he cut and spliced the wires, also under dash relay was loose don't know if that had anything to do with it but they are working. as for "the rest" I keep getting code p0136 o2 sensor low voltage ( bank 1, sensor 2) have gotten conflicting reports as to which sensor it is some say post cat some say pre don't want to buy the wrong sensor as I don't have the money to waste. new parking brake cable coming tomorrow, but need to know why they keep fraying under dash.
  17. Feb 1, 2016 at 10:44 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    glad it's fixed. I used a wire tap for my cap brake light.
    you never mentioned the code before this post ^ :oops:
    completely different (maybe new topic/post)
  18. Feb 1, 2016 at 11:40 AM
    norfolkpest
    02 tacoma manual
    good idea.
