No brake pedal pressure after bleeding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Danno2701, Jun 21, 2021.
  1. Feb 7, 2022 at 6:06 AM
    #61
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not only should you request a bleed you shouldn't pay them for making it worse.
    Did they bleed the ABS System?
    You also probably need to have the rears properly adjusted before you do anything they will greatly effect the pedal if they are too loose.
    TnShooter and Larzzzz like this.
  2. Feb 7, 2022 at 6:16 AM
    #62
    SB_ShovelSlayer
    SB_ShovelSlayer Well-Known Member
    Jonathan
    Woodstock, Georgia
    2013 TRD Sport Prerunner
    As far as I know they did not bleed the ABS system. When I go back tomorrow I will ask that their tech bleeds it properly for as long as needed and ask him about bleeding the ABS system too.
  3. Feb 7, 2022 at 7:23 AM
    #63
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you adjust the rear brakes when you reinstalled them?
  4. Feb 7, 2022 at 7:26 AM
    #64
    SB_ShovelSlayer
    Jonathan
    Woodstock, Georgia
    I did not but that is only because I did not remove the shoes after taking off the drums. I detached the e-brake brackets which gave me enough slack to remove the shaft with the brake assembly still intact.
  5. Feb 7, 2022 at 7:51 AM
    #65
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Jimmyh how true.
    Rear brake adjustment is critical to having a decent pedal.
    For the pain in the ass that the manual calls out as the procedure, it does lead to having a nice pedal at the end of the day. It's also a job I'd prefer to do with a lift, rather than contorted in some sort of new yoga position.
    OP, don't let them blow you off about bleeding the ABS either. I don't know if there are other options out there other than Toyota's Techstream software to do this though.
    You can find the cable and software needed with a little searching and do it yourself.
    SB_ShovelSlayer likes this.
  6. Feb 7, 2022 at 8:04 AM
    #66
    SB_ShovelSlayer
    Jonathan
    Woodstock, Georgia
    I'll see about the ABS as well. Pedal to the floor with zero brake power could really be tied to a need for rear shoe adjustment? That's wild to me, only because I always thought most of the stopping power came from the front brakes. This is probably a silly question - but would only bleeding the front calipers and not the rear bleeder screws make a difference? I'm wondering if the folks in the shop only bled the front calipers.
  7. Feb 7, 2022 at 9:12 AM
    #67
    Larzzzz
    Larry
    MA
    What happens is that as the front brakes wear, brake fluid takes up that space behind the caliper piston.
    The rear brakes are held open with springs pulling on each other, compressing the pistons back into the wheel cylinder everytime you take your foot off of the brake. As the rear brakes wear,. The star adjuster takes up space. If they're out of adjustment, more brake fluid is needed to push the shoes out farther, resulting in a lower pedal.
  8. Feb 8, 2022 at 5:31 AM
    #68
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes the rear shoe adjustment can cause this.
    Bleeding just the front would be stupid, I hope any shop would know better.
    Larzzzz likes this.
