No BS: Lifted and big tires, real mpg?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sig Taco, Apr 16, 2021.
  1. Apr 29, 2021 at 7:17 PM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    3” lift, 285/75/17’s (34”), stock gearing. I’m currently averaging (according to the computer) around 11-13.8 MPG, so in reality I’m getting 12-15 MPG. However, the majority (90%+) of my driving is currently on the highway with 65+ MPH speeds.
    I also noticed that I lose around the same fuel efficiency towing a trailer as I did before, generally 2-4 MPG on average.
  2. Apr 29, 2021 at 8:29 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    285/75….with. 1.5 inches. Just filled up and got 19 around town. Have 50k now, and I think my mileage has improved over the year. I bought one of those calibration boxes installed behind instrument cluster to change speedometer to match actual due to tire size. I’ve gotten 21 mpg on highway, no wind going 65 for a few hundred miles before with cruise on. Faster speeds kills mileage. I use gas buddy application to keep track of gas mileage.
  3. Apr 30, 2021 at 7:45 AM
    BOSS-DS2
    Sam
    Texas
    285/75/17 or 285/75/16? I would assume on a flat road if I set the cruise at 59-60 MPH (would be a real speed of 65-66) I could likely achieve at BEST 17-18 MPG. However many roads I drive on are not flat, my truck mainly stays in fourth, and occasionally fifth gear. If it’s in fourth and I know it CAN downshift I just blip the throttle and it increases RPM’s enough so that the truck shifts.
  4. Apr 30, 2021 at 7:51 AM
    BOSS-DS2
    Sam
    Texas
    Your average seems to be very similar to mine. Technically speaker my 34’s should be 10.7% larger than my factory tires were. However, I assume due to tire deflection the overall difference is less than 10%. For easy math in my head I still use 10%, makes it easy to “recalibrate” the speedometer while driving, and I also know I can multiply by 10% and add the difference to the computers MPG and it will give me a rough estimate of what I am actually achieving.
    In my case, even if I averaged 13 MPG that wouldn’t be bad considering when new I was averaging around 16-18 on a good day.
  5. Apr 30, 2021 at 7:54 AM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    285/75/17 Yokohama MT
    ~3" lift
    50/50 City/Highway
    Dash reads ~12-14 MPG
    Kdmax tune
    Stock AT Gears
    Got a Prinsu
    Slimline bumper + Winch + Sliders
    EDIT: - i could absolutely get better MPGs but i'd have to completely change my driving style
  6. Apr 30, 2021 at 8:02 AM
    BOSS-DS2
    Sam
    Texas
    What are you overage speed limits on that side of the country? I know with ours I couldn’t get close to those numbers.
  7. Apr 30, 2021 at 8:27 AM
    Ronk44
    Rockerville, SD
    2017 MGM Sport
    I actually installed converter box to correct speeds, and verified actual using GPS. My true speed matches speedometer.
  8. Apr 30, 2021 at 8:32 AM
    NWTacoTime
    Nate
    WA - Seattle/Kent
    Car Seats
    good question - out here on the highways its usually Max of 60 - 70.
    I know when i drive thru Idaho or go to Utah they got speed limits up to 80 MPH and my MPG numbers absolutely crash if i try to keep up with that
  9. Apr 30, 2021 at 8:51 AM
    BOSS-DS2
    Sam
    Texas
    I was only speaking in regards to my situation. Are your tires 33’s or 34’s?
  10. Apr 30, 2021 at 8:54 AM
    BOSS-DS2
    Sam
    Texas
    Speed limits here are generally 70-75 and my non-regeared truck doesn’t handle it well MPG wise.
  11. Apr 30, 2021 at 6:12 PM
    Ronk44
    Rockerville, SD
    2017 MGM Sport
    To clarify, My tires are 285/75/16 in size.
    BOSS-DS2[QUOTED] likes this.
  12. Apr 30, 2021 at 8:23 PM
    BOSS-DS2
    Sam
    Texas
    Just went to the Subaru dealer in Plano, was a 70+ mile trip one way, and I mainly used cruise control at 70-80 MPH. Computer said my average was 15.5, so in reality it was around 16-17 MPG.
  13. Apr 30, 2021 at 8:47 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    A whole lot of information you are asking for, but, I get about 17ish on a good day.
  14. Apr 30, 2021 at 9:03 PM
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    2021 Off Road (Double Cab, V6, 4WD, AT)
    Rough Country Speedo Calibrator (verified with two different gps apps)
    2” Spacer lift
    285/70/17 BFG All Terrain KO2 Load Range C @ 40 psi
    MB 701
    ~75% Freeway Driving @ 70-80 mph
    Mostly dry Phoenix weather ~50-90 degrees from late Jan until now.
    17.7 mpg.
    Best mpg I’ve got with this set up was driving to Palm Springs from Joshua Tree. All downhill coasting with a few climbs. 22 mpg.
  15. May 1, 2021 at 2:33 AM
    #35
    BK68
    BK68 Well-Known Member
    Love you Rig m8, which headlights are those?
  16. May 1, 2021 at 6:23 PM
    #36
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Thank you. Stock, just pulled them apart and painted the housings.
  17. May 1, 2021 at 8:52 PM
    #37
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    Sounds like you need OVTune ;)
  18. Feb 29, 2024 at 10:26 AM
    #38
    Alljst4fn
    Alljst4fn New Member
    I must have bought the worst mpg Tacoma it’s getting between 14.5 and 15.5 mpg. 13000miles on it and bone stock 50% highway 50% city. I’m afraid of what I’m gonna get with larger tires. I did get the OTT tune and really didn’t affect mileage. I drive up in Toronto Canada 253f ft. ASL, premium gas.
  19. Feb 29, 2024 at 10:41 AM
    #39
    Cboody69
    Cboody69 Well-Known Member
    GA/SC
    ‘22 AG TRD Sport XP DCSB 4x4
    TRD Lift
    I would like to add that location should be shared with this info. Different elevations, terrain types, temperature, weather, and humidity can have impacts on fuel economy. While it may be minimal, it is worth noting. Could be the difference in a MPG or two, in some cases. Example: my MPGs in GA/SC will likely differ from my same truck and setup in Upstate NY, or Mountainous CO...
  20. Feb 29, 2024 at 10:57 AM
    #40
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I love my cooper XLT in 285/75/16 and super bummed they are being discontinued for the new cooper tire that looks like a Goodyear parent company clone. They aren't the sexiest tire, but super quiet and compliant in almost all conditions.
    For OP, I average around 15 mpg on my tires (can get up to 18 if I baby it under the right conditions), if you haven't recalibrated your odometer you're getting better mpg than what is showing, but heavier tires, rotational mass, etc. is going to impact mpg.
