NO BUMPS BOUT TO ORDER EVERYTHING
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattB05SPORT, Apr 26, 2012.
  1. Apr 26, 2012 at 3:05 PM
    MattB05SPORT
    MattB05SPORT [OP] MATTBLEVINS
    GA
    05 PreRunner TRD Sport 4 Door
    STOCK BUT SOON TO BE MOD
    bout to order the new xd bombs. 18x9 0 offset. just to clear my conscience and get a 2nd opinion. im also ordering nitto terra grapplers 265/70/18. also the 5100s gonna lift to level the front. Does everything seem in place as far as no rubbing? bout to drop bout 2500 bucks on everything im getting so any help would be good.
    Thanks guys!
  2. Apr 26, 2012 at 3:07 PM
    TRDfarmerTN
    TRDfarmerTN Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    should be good to go man u gna set the 5100s to 1.75? i wna do a similar setup def post pics once u get it on
  3. Apr 26, 2012 at 3:11 PM
    MattB05SPORT
    GA
    yes sir i am i read that 1.75 is level
  4. Apr 26, 2012 at 3:13 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    as long as the backspacing on the rims arent greater then 4.5" u will be fine
  5. Apr 26, 2012 at 3:17 PM
    MattB05SPORT
    GA
    on the site it doesnt say the backspacing? thats one issue im gonna look at. how should i figure that out. im sure theres a thread
  6. Apr 26, 2012 at 3:19 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Backspacing isn't going to matter with 265's, if you are super concerned measure the distance from the back of the mounting surface to the lip on the back side of the rim.
  7. Apr 26, 2012 at 3:19 PM
    MattB05SPORT
    GA
    found it thanks alot guys. will post pics!
