No cargo light or power rear window with 2022 TRD Access Cab???????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dp1232, May 29, 2022.
  1. May 29, 2022 at 10:23 AM
    Dp1232
    Dp1232 [OP] Member
    D
    2022 Toyota Tacoma TRD Access Cab
    Hello,
    I just bought a 2022 TRD Off Rd Access Cab and it didn’t come with a powered rear sliding window or a cargo light. Don’t these features come standard with a TRD?
    Thanks
  2. May 29, 2022 at 10:25 AM
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    Not standard with TRD. Need premium technology package.
  3. May 29, 2022 at 10:32 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Both options are not available on access cabs.
    513Mugsy likes this.
  4. May 29, 2022 at 10:37 AM
    Dp1232
    Dp1232 [OP] Member
    D
    Thanks for the quick responses. Is this a new thing or has that always been the case?
    Thanks again
  5. May 29, 2022 at 10:46 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    In 2016, for Access Cabs cargo light, moon roof and JBL audio were not available. In 2016 no Tacoma had a power rear window.
  6. May 29, 2022 at 10:47 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Always the case with access cab
  7. May 29, 2022 at 10:57 AM
    TA2016
    Oregon
  8. May 29, 2022 at 11:06 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Just be glad that you don’t have to take off the headliner to change the third brake light bulbs.
  9. May 29, 2022 at 11:07 AM
    Dp1232
    Dp1232 [OP] Member
    D
    Interesting, I always thought the TRD’s came with that stuff standard.
    Great PDF!
    JJ Diablo likes this.
  10. May 30, 2022 at 5:47 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Yes, the OP should thank his lucky stars that he doesn't have the problematic third brake light with the built-in cargo light. If a bulb goes bad on his, he can just replace it from the outside. Plus, the housing is not known to leak.
    If you need a cargo light, the OEM bed lights are the solution. The wiring is there, but you have to get the dash switch. (The switch costs more than the bed light kit itself.)
