No CEL. Truck barely runs over 1000rpms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wtf_is_wrong, Sep 26, 2017.
  1. Sep 26, 2017 at 9:19 PM
    wtf_is_wrong
    wtf_is_wrong [OP] Member
    Piece of s***t toyota
    Stock
    And no I haven’t washed the truck or engine for a long time
  2. Sep 26, 2017 at 9:22 PM
    wtf_is_wrong
    Stock
    If it is the cat? Should I get an aftermarket one sense the Toyota ones have a bad history
  3. Sep 26, 2017 at 9:26 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Damn OP I think you need to take a breather. If this above your skill level maybe take it to a professional.
    What's fuel pressure?
    Has it overheated?
    What do your fuel trims look like?
    What are your 02 voltages?
    If you take the cat off does the truck run better?
    Restricted throttle plate?
    Mass have any debris on it?
    What's your compression readings on all 4 cylinders?
    Have you made sure the injectors are working properly?
    Have you used a noid light on the injectors?
    I can keep asking questions...
  4. Sep 26, 2017 at 9:42 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    This is where I would start.
  5. Sep 26, 2017 at 9:49 PM
    wtf_is_wrong
    Stock
    I’m chillin... just don’t have any respect for ppl with an IQ under 30.
    The fuel pressure is around 40, the motor hasn’t over heated at all, the compression test show about 185psi per cylinder. Cleaned the throttle body, and mass air flow with products for yoda. Haven’t checked the injectors, but would the injectors show sign of failure at start up? Or under a load? Tomorrow I will check the injectors and the cat. Thanks for the advice I will keep it posted..
  6. Sep 26, 2017 at 9:53 PM
    wtf_is_wrong
    Stock
    Thanks snowroxKT, ima check it out in the morning, to me the cat is a red flag but wanted some other input.
  7. Sep 26, 2017 at 9:53 PM
    Bebop
    Nick
    Try taking the cat off and going for a drive. It will be loud but it's what I do when I test mustangs with this problem. Pretty common on those piles of junk
  8. Sep 26, 2017 at 10:08 PM
    wtf_is_wrong
    Stock
    Awesome I will try that tomorrow, and I agree about the mustangs being a Chevy guy, my 67 Camaro has been more reliable then my toyota, who would have thought ha thanks man
  9. Sep 26, 2017 at 10:42 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I have more years of ASE certified experience behind me than you have in IQ points and you can take that to the bank. You don't know :poking: about me.
    You come in here with your first post begging for help because you did something stupid, offer very little in terms of things you have tried or even your trouble shooting process, dropping F-Bombs and then attack the people just trying to help and offer advice.
    Yeah have fun fixing your "P.O.S."
    Sounds like the problem exist in the steering wheel/seat/pedal linkage! :thumbsup:
    Oh yeah...
    :jerkoff::luvya::brianr::luvya::jerkoff:
  10. Sep 26, 2017 at 10:49 PM
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
    Man, shit like this is why I love this website. :bananadance:
  11. Sep 26, 2017 at 11:19 PM
    510tacoguy
    510tacoguy Well-Known Member
    Eduardo
    2004 4 door tacoma
    Body lift suspension lift
    :popcorn:...
    Roland79 likes this.
  12. Sep 26, 2017 at 11:26 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    All these intelligent folks trying to help you, and gather as much info as possible to assist you with a diagnosis after YOU ASKED and you disrespect them? Seriously? That's not how it works OP
  13. Sep 26, 2017 at 11:28 PM
    JoefromPTC
    Joe
    No need to keep us posted... We don't care anymore
    Stemmy, hoverlover, gnicks08 and 7 others like this.
  14. Sep 27, 2017 at 2:10 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  15. Sep 27, 2017 at 3:45 AM
    #35
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    @wtf_is_wrong i don't see you sticking around much longer here with the attitude you have towards the people trying to help you.
    Lighten up
  16. Sep 27, 2017 at 3:46 AM
    #36
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Neither do we. Keep in mind that you're the one with the broken truck, not us.
    If you provided basic troubleshooting steps that you've taken we could skip those as recommendations. Your request is "I replaced parts and now my truck is broken I'm going to burn it!!!" That's not the approach of a reasonable person so of course folks are going to address the rational, obvious, easy stuff first.
    If you want help, it's being offered. (We have some VERY skilled members around here.) If you just want to complain, stop wasting our time and yours.
  17. Sep 27, 2017 at 3:55 AM
    #37
    ChadsPride
    Sponsored by TacomaWorld.com
  18. Sep 27, 2017 at 3:55 AM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    BLUF: Don't be rude to people trying to help you.
    Sometimes the simplest things are the easiest to overlook. It's easy to get caught up in the moment and basic troubleshooting steps go out the window. For example, there was a thread here not too long ago where a persons truck dies on the road, everyone was suggesting all this different troubleshooting, etc. What really happened was they ran out of gas.
    There's no need to be snippy to someone taking the time out of their day to lend a hand.
    JoefromPTC and Key-Rei like this.
  19. Sep 27, 2017 at 7:40 AM
    #39
    dvd0020
    dvd0020 Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
  20. Sep 27, 2017 at 7:53 AM
    #40
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Unbelievable.
    @Key-Rei, please don't get discouraged in offering help, just because of an A-hole. It is appreciated!
    BassAckwards, Key-Rei and Fitz235 like this.
