No CEL. Truck barely runs over 1000rpms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wtf_is_wrong, Sep 26, 2017.
  1. Sep 26, 2017 at 7:20 PM
    wtf_is_wrong
    wtf_is_wrong [OP] Member
    Piece of s***t toyota
    Stock
    Hey everyone, I have an 2008 Toyota Tacoma 2.7 motor, it’s has been a great truck until a week ago now I can’t wait to take it to the desert and blow it the F**K up.. had an exhaust leak at the flange, barely made it back to my house and popped the hood and melted my o2 sensor plug. Fixed the exhaust leak, changed the up stream o2 sensor(denso) and spark plugs (denso) factory OEM plugs and now it idles like dog crap and dies if it goes over 1000rpms.. thinking of never buying a toyota again. I have expierence with mechanics, but I can’t figure this one out, I’m so frustrated..... if anyone can help please do so.
    Roland79 likes this.
  2. Sep 26, 2017 at 7:22 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    You put it in limp mode. What codes is it giving?
  3. Sep 26, 2017 at 7:24 PM
    wtf_is_wrong
    Stock
  4. Sep 26, 2017 at 7:24 PM
    wtf_is_wrong
    Stock
    I know it’s in limp mode
  5. Sep 26, 2017 at 7:24 PM
    Bishop84
    Bishop84 Well-Known Member
    remove the upstream o2 sensor and see if it runs better with the leak, the cat may be restricted.
  6. Sep 26, 2017 at 7:28 PM
    wtf_is_wrong
    Stock
    Okay, I’ll try that. The previous owner said he replaced the CAT about 6 months ago and showed receipts for toyota. So I kinda through that out of the equation
  7. Sep 26, 2017 at 7:29 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    There may not be a light but there's got to be a code
    For starters I would pull the terminals on the battery, remove the battery from the truck then connect the two teminals together for 10 minutes. Then reinstall the battery and attach the terminals appropriately. This will reset all computers to their basic programming and allows you to start fresh on your trouble shooting.
    See if the truck starts and runs with the same issues.
    It sounds to me like you may have connected something wrong when doing your plugs and are firing cylinders out of order.
    Harry, hoverlover and o0oSHADOWo0o like this.
  8. Sep 26, 2017 at 7:31 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    My money's on incorrect ignition timing/ firing order...
    hoverlover and Key-Rei like this.
  9. Sep 26, 2017 at 7:35 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Are you sure the light works? When you first turn the key on it lights up?
    Sometime it's the simple things.
    Key-Rei and o0oSHADOWo0o like this.
  10. Sep 26, 2017 at 7:39 PM
    wtf_is_wrong
    Stock
    I drained all the charge from the computer already but nothing changed still the same. And how could the ignition be connected wrong when the length of the harness connects straight into the coil packs????? And all cylinders are firing, it starts and runs with out misfire until over 1000rpms and dies
  11. Sep 26, 2017 at 7:44 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Is there any leaks on the intake tract that you take off to replace the spark plugs
  12. Sep 26, 2017 at 7:50 PM
    BlueSTL
    BlueSTL Well-Known Member
    Sounds like a restricted exhaust or plugged cat
  13. Sep 26, 2017 at 7:52 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    You see there scooter, he thinks of the simplest things first.
  14. Sep 26, 2017 at 8:02 PM
    wtf_is_wrong
    Stock
    I drained all the charge from the computer already but nothing changed still the same. And how could the ignition be connected wrong when the length of the harness connects straight into the coil packs????? And all cylinders are firing in order or else the start up would be bad as well right? runs with out misfire until over 1000rpms and dies
  15. Sep 26, 2017 at 8:05 PM
    Key-Rei
    Key
    Florida
    RPMS Revolutions Per Minute(s)? Lol
    Hey Bud I know this is frustrating as all hell and you just want your truck back but it sounds like you need to crack a cold one or two step back from it for a while, relax for a minute before coming back to this one.
    Engines are simple creatures, suck squeeze bang blow, they just need air fuel compression and spark, you are missing one, if you're damned sure the spark is good, compression is almost a given, as is air, so it has to be fuel.
    If it's dieing when getting to higher RPM and stumbling at idle but not throwing a code then it's probably related to fuel pressure. Look for a small (3/16) vacuum line that should be connected to a round metal project near the rear of your engine on one end and a nipple off the intake tube off the other end. This is the vacuum controlled fuel pressure regulator. It's possible you pulled it off either end when doing your plugs.
    memario1214 and T4RFTMFW like this.
  16. Sep 26, 2017 at 8:05 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    How did the truck run before you worked on it? Other than the exhaust leak of course.
    SnowroxKT likes this.
  17. Sep 26, 2017 at 8:36 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    My celica did this. Turned out to be a bad fuel pump. No codes given either
  18. Sep 26, 2017 at 8:40 PM
    rocklobster2008
    rocklobster2008 Well-Known Member
    Jayson
    Fort Worth, TX
    2008 Red Tacoma TRD Off Road
    Brute Force Fab front bumper Dobinsons Snorkel 35" Nittos Bilstein 5100s ICON leaf springs RSI SmartCap Bed Replacement Diode Dynamics lighting Custom built morimoto headlights RCI full skid
    Definitely check your cats. That high temp may have melted them. I had it happen in an old 96 Chevy s-10 blazer. I disconnected the exhaust before the cat and she ran like a bat of hell again haha it had the same symptoms tours did though.
  19. Sep 26, 2017 at 8:43 PM
    medic2230
    Murph
    Bama! Roll Tide
    Have you washed the engine lately or gotten water in the engine compartment?
  20. Sep 26, 2017 at 9:19 PM
    wtf_is_wrong
    Stock
    @Key-Rei.. yeah it’s a bit frustrating when people like you say some obvious shit, you think your the joe rogan of Toyota’s.. haha everyone knows how a motor runs, I get it, I’m not looking for a freshman level auto shop teacher..
    @Styx586. It was weird, it started running like shit when the exhaust leak started and it progressively got worse until I made it home, I’m leaning towards the cat being clogged. that would make sense, all the back pressure from the bad cat caused the flange bolts to stretch and that’s what caused the exhaust leak to melt my o2 sensor plug. And it hasn’t been able to run good sence the cat conv. was plugged. What do you think?
