No Check Engine Light
Discussion in 'Technical Chat' started by koozer22, May 12, 2011.
  1. May 12, 2011 at 5:01 PM
    koozer22
    koozer22 [OP] Member
    Ooltewah, TN
    2006 PreRunner SR5 TRD Offroad
    I just got my 2006 Prerunner V6 and took it to get emissions testing. The check engine light does not come on when the key is turned to "on". (Never thought I would actually want it to come on!)
    My first thought was that there was a bad bulb, but I took out the instrument cluster and discovered there are no bulbs, just lights on the board. All other lights are coming on.
    They found to OBD codes - both for the camshaft position sensor. I am going to replace that this weekend, but have no clue where to go for getting the check engine light back on
  2. May 12, 2011 at 5:04 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    wait, why do u want ur light on? so u can fail ur emissions???
    Edit: never mind i had to re read it, sounded confusing....
  3. May 12, 2011 at 6:10 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did you got truck used ?
    It looks like somebody remove the light to mask the sensor problem
  4. May 12, 2011 at 6:20 PM
    koozer22
    Ooltewah, TN
    Are the lights soldered in? If so, what's the best way to replace them.
  5. May 14, 2011 at 7:54 AM
    koozer22
    Ooltewah, TN
    Any idea where to buy the replacement bulbs? Just called Toyota dealership, and the only solution they have for me is to replace the whole instrument cluster for $280!
