No cigar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbcs1987, Feb 25, 2009.
  1. Feb 25, 2009 at 7:39 PM
    cbcs1987
    cbcs1987 [OP] Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Im in the middle of wiring bed lights in the back of the truck. I hooked everything up and just tried to turn the lights on but they didnt come on. The only thing that happened was the switch lit up red like its supposed to. Does anybody have any suggestions to the problem?
  2. Feb 25, 2009 at 7:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are you useing a relay?
  3. Feb 25, 2009 at 9:09 PM
    TheTacoManChach
    TheTacoManChach I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    their could be a short in the line
  4. Feb 25, 2009 at 9:48 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    bulbs burnt out? :shrug:
  5. Feb 25, 2009 at 9:55 PM
    TacomaYAK
    TacomaYAK The Reel Sportsman
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    did you ground each light good?
  6. Feb 26, 2009 at 9:37 AM
    cbcs1987
    Cody
    East Tennessee
    I think I did. I did the ground just like this guy did. http://www.tacomaworld.com/forum/2nd-gen-tacomas/22753-how-wire-bed-lamps.html
    I'm 99% sure they arent. I'll double check tonight
    That could be true. I had to make the lines longer. I ended up having to extend the wire with a wire that was just a hair bigger. Wander if thats the case?
    Im just using what came in the package. There were 2 lights, wires, and a switch. I've heard you need a relay in a lot of cases but I figured it should work like its supposed to straight out of the box. Who knows though. I'm very bad with electronics.
  7. Feb 27, 2009 at 9:47 PM
    cbcs1987
    Cody
    East Tennessee
    ok heres an update of the set up right now.
    I relocated both of the ground to really good spot(the switch and lights are sharing the same ground. is that ok?). Its wired just as this pathetic diagram shows. still no luck. as said earlier the switch is lighting up like it should but the lights wont come on
  8. Feb 27, 2009 at 9:54 PM
    gdctaco
    gdctaco Well-Known Member
    georgetown, ont
    06 access cab 4x4 O/R
    rr diff mod in-cab 110
    maybe you have it on the wrong terminals at the switch, if it matters. do you have a multimeter?
  9. Feb 27, 2009 at 9:56 PM
    TacomaYAK
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    my switch was not the one that lit up so it might be different, but i had no ground coming off the switch. the only grounds i had was for each light.
  10. Feb 27, 2009 at 10:03 PM
    cbcs1987
    Cody
    East Tennessee
    Thats weird then. I got my lights at autozone. same brand as yours and everything(pilot). but yeah mine has a ground coming off the switch and then a ground for the 2 lights.
    GDC, yeah I have a multimeter. I just gave up for the night. I'll pick back up in the morning. I'm positive the terminals are all in the right spot. I switched them earlier just cuz I ran outta ideas of what could be wrong n tried anyways. Its ridiculous I could take the engine apart n put it back together easier than I could fool with this electric stuff...
  11. Feb 27, 2009 at 10:07 PM
    TacomaYAK
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    so there are 3 male connects on the back side of the switch?
    mine only has two, one for the power wire going to battery, and one for the power wires going to the lights (both lights connect to each other and split off as one). then each light is grounded only the the frame, and not the switch.
  12. Feb 28, 2009 at 11:39 AM
    cbcs1987
    Cody
    East Tennessee
    ok turns out i didnt do anything wrong. not as dumb as i thought i was. the switch was bad. went to the store and got another one. works like a charm! i love these lights
  13. Feb 28, 2009 at 11:47 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    blown fuse????
    mabey too much power for the fuse ur runnin?
  14. Feb 28, 2009 at 2:36 PM
    Liam1234
    Liam1234 Well-Known Member
    Massachusetts
    09 DC, LB, TRD Sport, 4x4, Tow, Magnetic Grey
    Access Literider Tonneau Cover Auto Remote Start Nfab side steps
    Glad you perservered and got it working! Nice job. Post some pics!!
  15. Feb 28, 2009 at 2:41 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    It's a lighted switch. The ground is for the return for the light inside the switch.
  16. Feb 28, 2009 at 9:25 PM
    cbcs1987
    Cody
    East Tennessee
    will get some tomorrow! thanks for helpin out as always everyone :cheers:
