No clearance lights... 1st Gen.
Discussion in 'Lighting' started by vincevs, Aug 29, 2011.
  1. Aug 29, 2011 at 8:02 AM
    vincevs
    vincevs [OP] Well-Known Member
    Vince
    Alberta, Canada
    I'm leasing so I need to keep this a secret.
    Hey guys... my buddy was driving behind me in my 2000 (had to drop it off) and the clearance lights stopped working.
    Is there a fuse for these specifically?
    All my other lights work including signal lights and brake lights.
    After wiggling the wires my front right signal burnt out... so the right signal does the fast click. I will replace the bulb but I think there might be another problem.
    Any ideas?
  2. Aug 29, 2011 at 7:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Fuses? There is also a relay for parking lights only I believe. Used to be under the dash on the old trucks. Not sure on a Taco, havn't had that issue yet.
  3. Aug 29, 2011 at 7:44 PM
    vincevs
    Vince
    Alberta, Canada
    There is a 10 amp fuse in the box next to the battery. Got her fixed!
  4. Aug 31, 2011 at 12:03 AM
    Linelock4
    Linelock4 Member
    Jared
    New Hampshire
    04 Extra-cab V6 5-speed 4x4 Limited TRD
    Spectra intake and Air-Raid throttle body spacer.
    If you are talking the parking lights/running lights. Check if there is a trailer plug. I live in the North East and the salt from plowing gets in the plugs and causes all kinds of problems including shorts. Everyone forgets to look in the trailer plug.
