No Click no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by SUSPICIOUS_ BACON, Apr 19, 2023.
  1. Apr 19, 2023 at 4:18 PM
    SUSPICIOUS_ BACON
    SUSPICIOUS_ BACON [OP] Member
    2002 Tacoma ExCab 2.4L
    Hey everyone first time posting got an issue with my 2002 tacoma its a 2.4 L only has 150,000 miles on it but it won’t start the lights dim when I tried to turn it over, replaced the starter, the starter fuse the 120alt fuse the 7.5 alt starter fuse, checked the battery with a multimeter got 13v, not sure what else it could be and suggesting?
  2. Apr 19, 2023 at 4:26 PM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    neutral switch?
    wilcam47 likes this.
  3. Apr 19, 2023 at 4:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ll be more than happy to assist you in diagnosing it.
    Do you have a Test Light or a Voltage meter?
  4. Apr 19, 2023 at 4:57 PM
    SUSPICIOUS_ BACON
    It’s a manual but I’ll grab a clutch starter switch see if that works
  5. Apr 19, 2023 at 4:58 PM
    SUSPICIOUS_ BACON
    Yeah I got a multimeter
  6. Apr 19, 2023 at 4:58 PM
    TnShooter
    Deogee
    STOCK
    I would not buy anything yet.
    Go down to the starter and see if you have power to the small black/white wire while cranking.
    Also check the big black wire. It should have power all the time.
  7. Apr 19, 2023 at 5:21 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    SUSPICIOUS_ BACON[OP] likes this.
  8. Apr 19, 2023 at 5:26 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you try jump starting?
    b_r_o and HondaGM like this.
  9. Apr 19, 2023 at 5:46 PM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Lights dimming while trying to start usually indicates a weak battery. How old is it? I'd also try jump starting even though you have power, might need just a little bit more to get her going.
    HondaGM, Jp260z and wilcam47 like this.
  10. Apr 19, 2023 at 5:55 PM
    TnShooter
    Deogee
    STOCK
    Putting a meter on the battery while cranking would give us general idea on the state of the battery.
    Surely OP tested the battery before replacing the starter?
    HondaGM likes this.
  11. Apr 19, 2023 at 6:04 PM
    Jp260z
    Jp260z Well-Known Member
    2017 Tacoma DCSB SR
    You have lights (because they dim) so there at least some power in the battery. My first move would be checking voltage at the battery, you said 13v. That is usually good. I'd confirm that you have the SAME voltage that you measure across the battery at the main fuse box under the hood (the one that feeds the vehicle).
    Check that one by placing the positive probe on the main lug where the box is getting power from the battery positive cable. You can use the negative battery lug for ground. There should be no voltage loss here, if there is you have either a bad connection (corrosion, loose, etc) or bad wire from the battery to the box. I have seen vehicles measure 12 or 13v at the battery measure 3 or 4v here....enough to power lights but not nearly enough to kick an engine over.
    Friend of Crows likes this.
  12. Apr 19, 2023 at 6:07 PM
    Friend of Crows
    2022 Tacoma SR
    Corroded and loose connections at the battery could definitely play a factor.
    HondaGM, Jp260z[QUOTED] and wilcam47 like this.
  13. Apr 19, 2023 at 6:25 PM
    TnShooter
    Deogee
    STOCK
    You don’t typically see a voltage drop unless you’re testing under a load.
    Jp260z and HondaGM like this.
  14. Apr 19, 2023 at 6:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW..
  15. Apr 19, 2023 at 6:48 PM
    Jp260z
    2017 Tacoma DCSB SR
    Agreed.
    Or if there is an issue such as a bad connection.
    TnShooter[QUOTED] likes this.
  16. Apr 20, 2023 at 2:22 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Check the condition of your battery terminals.
  17. Apr 20, 2023 at 12:51 PM
    TnShooter
    Deogee
    STOCK
    While checking the battery terminals is good advice.
    One would think OP had to have looked at them when he dissected the batter to replace the starter.
    Unless he didn’t disconnect the battery?
  18. Apr 21, 2023 at 5:46 PM
    SUSPICIOUS_ BACON
    Thank you everyone turns out it was the clutch safety switch was not engaging due to the plastic plunger breaking off
  19. Apr 22, 2023 at 7:19 AM
    aroma
    Snottsdale AZ
    thanks for the update.
