No clutch accumulator on the 5MT?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NewMexiMan, Oct 7, 2020.
  1. Oct 7, 2020 at 7:19 AM
    NewMexiMan
    NewMexiMan [OP] Well-Known Member
    2016 SR 5 Speed
    Seen a lot of posts about the very bad no good double mean clutch accumulator on the 6 speed MT. Does the 5 speed MT have one as well? The clutch design on the 5 speed seems somewhat simpler.
    trackdaybro, Junkhead and tonered like this.
  2. Oct 7, 2020 at 7:22 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Junkhead and shakerhood like this.
  3. Oct 7, 2020 at 10:09 AM
    NewMexiMan
    2016 SR 5 Speed
    Thanks. Now I can finally tell my doctor I'm accumulation free.
  4. Oct 7, 2020 at 10:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Congrats! :D
    It is pretty sad that we had to manually cut it out.
    Doobfucious and Junkhead like this.
  5. Oct 7, 2020 at 10:49 AM
    NewMexiMan
    2016 SR 5 Speed
    Now I'm curious what the 6MT feels like. Certainly everything about the transmission on my truck feels alive and unadulterated.
  6. Oct 7, 2020 at 10:51 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    We need that accumulator on the v6 to dampen all that mega torque.;)
    BassAckwards and Chew like this.
  7. Oct 7, 2020 at 10:52 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I love this 6MT, especially without the accumulator. Tranny is nice and smooth, just needs a few mods to make it perfect.
    tonered and Natetroknot like this.
  8. Oct 7, 2020 at 10:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    New, the 6MT felt nice and only got better with break in. The main break in happened in about 1k, but 1st took a while longer.
    Eventually, I had a couple times where getting into 1st at a stop was difficult. That was fixed with Redline MT-90.
    The biggest issue with the accumulator was imprecise downshifts. Rev matching and smoothness was difficult. It is something that appears over time when I normally would be used to an MT, not still second guessing and hyper aware. That started my search for the accumulator because I knew that most new MTs have them.
    With the ADM, Redline, and time / use, the 6MT is as nice as any other MT that I have driven other than a Miata. The TSB and OVT tunes also improved shifting.
    Natetroknot, shakerhood and Junkhead like this.
  9. Oct 7, 2020 at 10:55 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I agree! After doing the ADM the other day I went ahead and ordered URD's kit to shorten the throws - looking forward to shifting bliss
    Doobfucious and tonered like this.
  10. Oct 7, 2020 at 10:59 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Nice! The 2wd LOW mod is amazing as well. The reverse sucks otherwise.
    shakerhood and tonered like this.
  11. Oct 7, 2020 at 11:20 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That problem I've decided to live with - there is too much crazy push-this-shift-that goofy sequence stuff for me to remember
    That problem will only get solved if I do the freewheel hub conversion, so it's probably something I have to live with.
    Seldom tow, but when I do.....man that tall a reverse SUCKS.
    tonered and Junkhead[QUOTED] like this.
  12. Oct 7, 2020 at 11:21 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Its super easy man, just hit the switch before you go into 4hi and then 4lo. Everything is the same, except for that 1 push of a button. I would highly recommend it.
    tonered and Natetroknot[QUOTED] like this.
  13. Oct 7, 2020 at 11:38 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Huh, really? I felt like after I read up on it I told myself I'd need a cheat sheet on the visor to remember it. Thanks for the info! :thumbsup:
    Junkhead[QUOTED] and tonered like this.
  14. Oct 7, 2020 at 11:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is that easy. Push the button first going into 2Lo or coming out of 2Lo.
    Also, you can use the 2LM in 4Hi to get that 10mi of exercise every month, if needed. No more worries about dry roads and corners binding things up. You'll just want to flick in actual 4Hi from every once in a while to cycle the ADD actuator.
    Regardless, the free hubs are still on my wish lists. Someday!
    Natetroknot[QUOTED] and Junkhead like this.
  15. Oct 7, 2020 at 11:55 AM
    NewMexiMan
    2016 SR 5 Speed
  16. Oct 7, 2020 at 12:50 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Like having a pillow on top of the clutch pedal. When it's 50°F or below, the pedal moves slower and is really slow to return up. Down near 15°F, I nearly have to pull the pedal up with my toe until it warms up.
    I'll rip that trash out tomorrow afternoon, I think. It's the only nagging thing about the truck in 16,000mi. I've driven a dozen cars long-term that had various restriction tricks in the clutch systems but none were near the Tacoma's poor characteristics. Most I knew they were there but was able to adapt fine. I'm going to damage something in the trans if I dont get rid of this thing. They say it's to help novice drivers but it will do nothing but set them up for failure when they drive something normal and fun. That and to protect toyota from claims from d-bags dropping the clutch and breaking something. I'm leaning toward that one, it's more likely that a company will spend money to save money than to just be nice.
    Be glad you don't have one but at least it's a super easy "fix."
    Natetroknot, Junkhead and tonered like this.
  17. Oct 7, 2020 at 12:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Given that it looks like a science project to start with, there should be a pull pin bypass in the damn thing to give everyone the opportunity of a no hassle delete.
    Beyond the Clutch Pedal, it's not like there is much warranty possibility after a few K anyway.
    Junkhead and Doobfucious[QUOTED] like this.
  18. Oct 7, 2020 at 12:59 PM
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    +1
    I had the vacuum setup go out (surpriiiise) on a 1st gen S10 4.3 4x4 MT and put a posi-lok cable actuator in as a replacement, thus yielding 2LO. It was awesome! I wouldn't have believed it was that handy when people talked about it but it was a convenient byproduct of fixing the front diff and it was glorious! It made backing a trailer or up a steep driveway so graceful. That's not a word often used in the context of a 1991 S10 :rofl:
    In certain other manufacturers, there's literally a restrictor pill you remove, bleed and you're done. I'm still ok with this setup and solution, what if it required machining an internal slave cyl to fix? Nah, son :laugh:
  19. Oct 7, 2020 at 1:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. A friend said that Bimmers were like that. He didn't keep it long enough to actually mod it.
    Very true though. I was encouraged by the vid of the 2nd Gen'ers just tossing on a coupler. The dremel mod is the way to go though. I am thinking about yanking out my brake line elbow and tossing in the dremel mod. I'm not a big fan of my safety wire.
    Doobfucious[QUOTED] and Junkhead like this.
  20. Oct 7, 2020 at 3:03 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    @Doobfucious
    I literally just turned 16,000 miles on my '19 and just did the ADM last Sunday, wish I had done it a LONG time ago, just light a fire under your arse and hit up O'Reilly this wknd
    tonered, Doobfucious and Junkhead like this.
