no courtesy lights
Discussion in 'Technical Chat' started by Big Dog Trukin, Apr 7, 2014.
  1. Apr 7, 2014 at 4:45 PM
    Big Dog Trukin
    Big Dog Trukin [OP] New Member
    Hoboken, GA
    03 prerunner SR5 TRD
    Can someone tell me if there is a relay for the door/courtesy lights in my 03. The dome will work in "on" position but not in "door". All fuses are good.
  2. Apr 8, 2014 at 4:55 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I don't know about a relay, but you might check out the headliner switch or the connection coming from the door switches.
  3. Apr 8, 2014 at 5:45 PM
    Big Dog Trukin
    Hoboken, GA
    Thanks, I will look at those this weekend. Hope I didnt do any major damage. I was hooking up some aftermarket led's to the dome/courtesy light and grounded out the "door" wire. From what I understand the "on" and "door" switch both run off the same fuse. Just figured it had some sort of relay to have the courtesy lights stay on for a min. or so after you close the doors. Any help is greatly appreciated.
  4. Apr 9, 2014 at 7:25 AM
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    It occurs to me that the timer is probably integrated into the BCM.... :der:
