no crank no start after engine install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Aug 2, 2013.
  1. Aug 2, 2013 at 8:11 PM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    all my wires are hooked up that i can see.
    starter worked until i pulled my original engine. any ideas?
    dont think it could be a fluke that it went bad but you never know....
  2. Aug 2, 2013 at 8:13 PM
    cj.ainsworth77
    cj.ainsworth77 Well-Known Member
    CJ
    Texas
    02 Reg Cab 2wd
    This has happened to me before haha...you're sure there isn't apcm ground wire hanging loose? I'm assuming that the dash lights up and everything when you put the key to run right?
  3. Aug 2, 2013 at 8:15 PM
    Hambone155
    omaha
    yea they do. only idea i have is that i dont have radiator in.... would it not crank starter because of no coolant? radiator isnt hooked up....
  4. Aug 2, 2013 at 8:18 PM
    cj.ainsworth77
    CJ
    Texas
    02 Reg Cab 2wd
    I seriously doubt it...you could always pull the starter and test it on the bench to see if it's any good
  5. Aug 2, 2013 at 8:21 PM
    maytagworker
    maytagworker Well-Known Member
    Check for 12v at starter and power at signal wire on starter when ign at start, if you got both of those and starter grounded you got a bad starter, my dads starter was working fine before I did the 3.4L swap in his 92 Toyota, once the 3.4 went in started just took a dump
  6. Aug 3, 2013 at 7:36 AM
    Hambone155
    omaha
    No signal at solinoid wire. Replaced most of the wire. ECM not plugged all the way in? I want to get this bastard started today.
  7. Aug 3, 2013 at 7:45 AM
    BamaToy1997
    Bill
    Navarre, FL
    I know this may sound silly, but did you check to make sure that the starter fuse and relay are good? Also, it may SEEM like it is perfect and tight, but a bad battery connection WILL allow the dash lights and such to come on, but wont let the starter engage. Remove battery terminals, clean both the terminals AND the cables, and reinstall. Just a few suggestions.
  8. Aug 3, 2013 at 7:46 AM
    Hambone155
    omaha
    ECM connector. Pulgged it in all the way and starter motor fired. So pissed at myself
  9. Aug 3, 2013 at 8:07 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Congrats!! You have leveled up!!
    Hambone is evolving!
    Hambone is now a Technician!
    Dude it happens to all of us! Obvious things are often overlooked.
  10. Aug 3, 2013 at 9:02 AM
    cj.ainsworth77
    CJ
    Texas
    02 Reg Cab 2wd
    Congrats man
  11. Aug 3, 2013 at 9:35 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Huzzah! Glad you figured it out. Don't feel dumb- mine wouldn't start when I did my rebuild because we forgot a ground. xD
  12. Aug 3, 2013 at 12:18 PM
    Hambone155
    omaha
    Ill post a vid later but built motor roving hard.
  13. Aug 4, 2013 at 10:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    Glad to hear you got it all figured out! Congrats!
