No Crank Post Battery Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrock1290, Jul 18, 2022.
  1. Jul 18, 2022 at 11:12 AM
    jrock1290
    jrock1290 [OP] Member
    Swapped out my old battery that had a bad cell with a new one today. Wasn't paying attention and left the ignition switch in the on position while I installed the new battery (yes yes rookie move). Got a little spark and one of the relays fired on and off for a few seconds.
    When I went to start for the first time I got nothing (all the accessories do turn on however). No rapid clicking like when the battery is dead. Confirmed the new battery is outputting 12+ volts. Tested the starter relay and every fuse under the hood and in the cabin and even swapped in the horn relay but still now dice. Tested the continuity of the negative terminal wire as well.
    Was wondering what to try next? Could I have destroyed the start solenoid with the live wire install? Feeling pretty dumb right now and am not sure what to do next
  2. Jul 18, 2022 at 11:27 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  3. Jul 18, 2022 at 11:30 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    You tried to lock the truck and unlock it? Security might have cut the starter circuit.
  4. Jul 18, 2022 at 11:31 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Any lights at all? Inside outside?
  5. Jul 18, 2022 at 11:33 AM
    jrock1290
    Yes, the lights inside and outside are working.
  6. Jul 18, 2022 at 11:39 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So everything else seems to work but the truck will not crank?
    BassAckwards likes this.
  7. Jul 18, 2022 at 11:41 AM
    TnShooter
    Deogee
    STOCK
  8. Jul 18, 2022 at 11:46 AM
    jrock1290
  9. Jul 18, 2022 at 11:49 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Hymm, never heard of installing a new battery with key in the ON setting, but dont see how that can damage anything unless you shorted something during the install. Try disconnecting the battery for a few minutes, with key out of the ignition, and see if that resets things.
  10. Jul 18, 2022 at 12:34 PM
    TnShooter
    Deogee
    STOCK
    No, you want to read voltage.
    Also, don’t jam the probes in to hard. You could damage the terminals.
    They aren’t that easy to damage, but I always like to warn people.
    Touching the terminal is good enough.
  11. Jul 18, 2022 at 1:39 PM
    jrock1290
    Thanks to all the quick responses. Disconnecting the battery for a few minutes did the trick. Curious as to why/how this fixed it.
    Chuy[QUOTED] likes this.
  12. Jul 18, 2022 at 4:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd bet there's an aftermarket alarm on it. The stock starting system is nothing but switches and relays, there's no computers involved and the immobilizer only disables fuel not the starter.
    TnShooter likes this.
