no cruise, what to try next??
Discussion in '1st Gen. Tacomas (1995-2004)' started by chips, Oct 16, 2013.
  1. Oct 16, 2013 at 6:16 PM
    chips
    chips [OP] Active Member
    My cruise isn't working. I can't even get the cruise light to come on when pushing the switch. I've checked both the brake and clutch switch and they are engaging how they shoulld. Not sure how to test to see of they are working properly though. What else goes wrong with the cruise? What's weird is it turned on for me once abt a week ago but now nothing.
  2. Oct 16, 2013 at 7:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Check the actual unit under the hood. Sometimes the connector gets loose.
  3. Oct 16, 2013 at 7:24 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    check the cruise fuse.
  4. Oct 17, 2013 at 1:15 PM
    chips
    Not sure where that's located but I just checked all the plugs arnd the throttle body and no change
  5. Oct 17, 2013 at 1:23 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    On the 2nd gens it's the clockspring is the central plug in spot for the cruise control, airbag and steering wheel controls..
    My cruise stopped working on my 2nd gen but it was clockspring that was bad
    Try holding the wheel at a 9 o clock position and push the switch to see If it turns on
  6. Oct 17, 2013 at 2:22 PM
    chips
    Still nothing
    Appreciate the help though, any other ideas???
  7. Oct 17, 2013 at 2:29 PM
    BamaToy1997
    Bill
    Navarre, FL
    When you say" still nothing" Could you be more specific about what you did, and how you tested it? You need to use a volt meter and/or a test light to check some things. You can't just look at a clock spring for example and tell if it is bad or not. Do you have a wiring diagram? I would look at one and start with finding out if there is power to the cruise switch first. Then check the power signal return wire to see if you are getting anything back.
  8. Oct 17, 2013 at 4:20 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    check brake light fuse
  9. Oct 17, 2013 at 5:29 PM
    AddictedOffroad
    AddictedOffroad Well-Known Member
    Windsor, CO
    2000 4runner. Linked and locked
    Does your horn work?
    A bad clock spring will kill the cruise and horn. Not the airbag as it ride on a different circuit.
    I bet your clock spring is bad and needs to be replaced.
  10. Oct 17, 2013 at 5:37 PM
    bmka87
    bmka87 Well-Known Member
    Josh
    Southern Maine
    97 Tacoma SR5
    had a 96 cherokee, no cruise not even a light. Found some plastic vaccum hoses near the battery that got corroded and cracked and split. Had no clue what these lines did but I wrapped them in electrical tape and put a rubber hose to connect them. Once I did that everything worked as it should. Not sure if the taco's have that too...haven't looked....but maybe try something like that?
  11. Nov 16, 2013 at 9:41 AM
    buckeyejohn
    buckeyejohn New Member
    Phoenix
    2004 Tacoma Quad cab 4x4
    My 2004 Tacoma (auto) had an issue where the cruise control worked fine so long as the headlight switch was off. As soon as the switch was turned to the parking lights or headlights, the cruise cut off like I hit the brakes. The culprit was a tail lamp/stop lamp bulb. One of the filaments sagged and was touching the other filament and arcing over. Replaced that bulb and everything is fine now. Please note that the bulb functioned normally, only on close visual inspection did I see the issue.
  12. Nov 16, 2013 at 6:08 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    check to see if you e-brake is resting all the way.
  13. Mar 12, 2014 at 5:07 PM
    chips
    Horn doesn't work. Cruise worked again shortly today but then stopped working ): no cruise light at all. Would it come and go like it has with a bad clock spring?
  14. Mar 12, 2014 at 7:59 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Do you have a manual?
    If so engage CC and set it then pull the clutch pedal up with your foot and it may engage. Thats how my work
  15. Mar 13, 2014 at 5:47 AM
    chips
    Yea I do. My cruise light wont even come on to engage so thats not the problem
  16. Mar 14, 2014 at 8:33 AM
    AddictedOffroad
    Windsor, CO
    Yes, it could be the issue.
