No dash lights 2005 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fairhopetacoma, Feb 23, 2015.
  1. Feb 23, 2015 at 7:39 PM
    Fairhopetacoma
    Fairhopetacoma [OP] Active Member
    Dan
    Fairhope, AL
    05 4WD double cab
    So I am having a weird electrical problem, hope someone can help.
    I have no dash lights on the instrument cluster. If I pull the IG1 no2 fuse out the dash lights come on. This also put my check engine light on :mad:
    Any ideas on what could be going on?
  2. Feb 25, 2015 at 5:47 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I've checked fuses, all are good. Any ideas?
  3. Feb 25, 2015 at 6:22 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    7.5 amp ECU-B fuse in engine bay.
  4. Feb 25, 2015 at 6:47 PM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Another member a while back had the same problem, and it turned out that the dimming nob had been turned all the way down by someone in his family. It's always worth a look.
  5. Feb 25, 2015 at 7:53 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I'll check the ECU-B fuse tomorrow too cold now.
    I've checked dimmer knob, still controls the heater controls and gear indicators
  6. Feb 25, 2015 at 8:08 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I tried the ECU-B, no change.
    The thing that has me completely stumped is if I pull the IG1 no.2 fuse out I have dash lights.
  7. Feb 25, 2015 at 8:19 PM
    Coma12
    Coma12 Active Member
    David
    Denver
    Tail fuse, behind the coin holder. This fuse is for dash lights too. Replace it.
  8. Feb 25, 2015 at 8:24 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I've tried the tail fuse too, no change.
  9. Feb 25, 2015 at 8:28 PM
    2011supercoma
    2011supercoma Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
    Did you recently install a new radio?
  10. Feb 25, 2015 at 8:43 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    Yes but the dash lights were out before that.
    Factory unit stopped working a few months back, then about a month ago the dash lights stopped. I figured that was related to the radio, but they didn't come back with the new radio.
    Old radio stopped working because a certain 2 year old thought it was a piggy bank when I let her sit in the car while I was vacuuming it.
  11. Feb 25, 2015 at 8:45 PM
    2011supercoma
    nola
    There's an orange wire from the wire harness, it's to dim your radio when the lights come on, check it to make sure it isn't shorting.
    I did that like an idiot on my first tacoma in 08.
    If not good luck man.
  12. Feb 28, 2015 at 1:54 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    Checked the harness, still didn't do it. Completely stumped, may be off to Toyota and their $125 diagnostic fee.
  13. Feb 28, 2015 at 5:51 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    When you pull out the fuse and the dash lights work - what is now NOT working??
    Also - try unplugging/disconnecting the radio HARNESS just to be sure the issue is not being caused by the radio.
  14. Feb 28, 2015 at 8:43 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I'm talking about the back lights on the cluster. Warning lights, gear and turn signals still light up.
    Canufixit, I'm going to check what doesn't work tomorrow, there is a lot of stuff on that fuse, and yes I pulled the harness today, I even cut the Orange wire on the harness to see if that was causing my issue.
  15. Mar 1, 2015 at 4:36 AM
    Canufixit
    New England
    Could it be related to the "dimmer" wire that goes to the radio??
  16. Mar 1, 2015 at 9:14 AM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    Tail lights work and rest of the illumination does as well.
    It could be related to the radio dimmer I guess, that doesn't dim, but everything on the radio harness and toyota side is connected properly.
  17. Mar 1, 2015 at 9:36 AM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    When I pull the ig1 no2 fuse out dash lights up but tail and head lights go out
  18. Mar 1, 2015 at 9:52 AM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    I think it's a bad dimmer, I just pulled it out and now I have dash lights
  19. Mar 1, 2015 at 10:40 AM
    Canufixit
    New England
    Hope that's it. Please let us know ....
  20. Mar 1, 2015 at 5:10 PM
    Fairhopetacoma
    Dan
    Fairhope, AL
    05 4WD double cab
    Will do, off to the u pull it on Tuesday
