No Dash lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marke8264, Nov 17, 2022.
  1. Nov 17, 2022 at 1:15 PM
    marke8264
    marke8264 [OP] New Member
    Mark
    2013 Tacoma
    So I attempted to replace my foglight switch with a after market one. I blowed my fuse for my dash lights. No biggie I just replaced it. Then I did it again this time my speedometer lights went out as well and now I can't get them back on. Any ideas.
  2. Nov 17, 2022 at 1:47 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    After market will kill your one way or another
    I know, I just had to buy one 54.00!!!!
    I know there are very smart guys around here @Dm93
    I suspect fuses though
    marke8264[OP] likes this.
  3. Nov 17, 2022 at 3:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 7.5A Gauges and 10A Tail fuse both power the dash and interior lights.
    Check both.
    FWIW, most aftermarket switches are setup for power side trigger to the relay.
    The OE wiring is setup for Ground side.
    marke8264[OP] and Dm93 like this.
  4. Nov 17, 2022 at 6:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You may have fried your rheostat, do any of the other backlights work?
    Why were you replacing the fog light switch? They rarely go bad.
  5. Nov 18, 2022 at 9:04 AM
    marke8264
    Mark
    2013 Tacoma
    Yeah nothing was wrong with the old switch. I just wanted one that lite when the lights were on. Should have just left it alone.
  6. Nov 18, 2022 at 9:06 AM
    marke8264
    Mark
    2013 Tacoma
    My speedo lights and heater lights are both out. I was thinking it could be the dimmer switch.
  7. Nov 18, 2022 at 9:10 AM
    TnShooter
    Deogee
    STOCK
    I think if you unplug the dimmer, the lights go full bright. If memory serves me correct, @Jimmyh and I had a heck of a time a few years ago helping a member here figure out why the dash lights would not dim. Turns out the dimmer was fried and previous owner unhooked it.
    The cause was an aftermarket radio wired incorrectly.
    marke8264[QUOTED][OP] and Dm93 like this.
  8. Nov 18, 2022 at 9:30 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    New OEM switches do light up. FYI
  9. Nov 18, 2022 at 9:53 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think he means light up when the fogs are turned on which the OE switch does not.
    Aftermarket switches are tricky to wire correctly due to the circuit design of the OE system.
    TnShooter likes this.
  10. Nov 19, 2022 at 3:37 AM
    marke8264
    Mark
    2013 Tacoma
    DM93 you are correct. I installed a light bar that lights up blue and liked it so I got a switch for my fog lights as well. But boy has it been a headache. Plan on working on it today hopefully get it figured out. Thanks for the ideas. I think I may have fryed my dimmer switch guess I'll be replacing it.
