No dash or a/c power, weak wipers
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98tac24, Aug 27, 2025 at 5:28 AM.
  1. Aug 27, 2025 at 5:28 AM
    98tac24
    98tac24 [OP] Member
    Wednesday
    1998 tacoma 2.4
    1998 2.4, 355k, trying to keep it running.
    The a/c on dash has gone out, doesn't appear to be getting power. And the dash display has no power or light. Speedometer not working. Suspect fuel gauge not working. Windshield wipers moving slow.
    So I suspect some single problem is causing all of this. If anyone has a wiring diagram or suggestions, thank you.
  2. Aug 27, 2025 at 12:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A low system voltage could cause all of those issues. Does the truck start and run?
    Wulf and ControlCar like this.
  3. Aug 27, 2025 at 12:41 PM
    98tac24
    98tac24 [OP] Member
    Wednesday
    1998 tacoma 2.4
    Yes, starts and runs though seems to be missing, rough.
  4. Aug 27, 2025 at 12:43 PM
    98tac24
    98tac24 [OP] Member
    Wednesday
    1998 tacoma 2.4
    I'll check the voltage tonight, good idea.
  5. Aug 27, 2025 at 2:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you have a multimeter, check the voltage at the battery while it is running. And also check it after it has been setting for an hour or two after turning off the engine (resting voltage).
  6. Aug 27, 2025 at 2:03 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Might be ground issue. Bad grounding can cause all sorts of problems.
    Wulf and Steves104x4 like this.
  7. Aug 27, 2025 at 3:29 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    i would firstly guess as others above....voltage/alternator issues
    det107 and Moonrman like this.
  8. Aug 28, 2025 at 5:31 AM
    98tac24
    98tac24 [OP] Member
    Wednesday
    1998 tacoma 2.4
    Voltage at battery is 12.25 when not running. 11.75 when running. 11.50 when running with lights turned on.
    I cleaned the ground from battery to body. Are there other grounds i can check? Inside the cab? I notice that the side-to-side support beam behind the dash is rusted.
    ControlCar likes this.
  9. Aug 28, 2025 at 6:07 AM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    I had similar symptoms. Bad alternator...
    det107 likes this.
  10. Aug 28, 2025 at 11:13 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Voltage at the battery when running should be 14 volts. Minimum 13 volts.
    Poor grounds may be a factor overall but the alternator output is a red flag. 11.75 while running is very low. Either the alt is not producing enough (most likely) or the battery is not accepting the input from the alt.
    My first step would be to disconnect the cables from the battery and clean them up and then reconnect to eliminate the possibility it is a battery issue.
  11. Aug 28, 2025 at 12:25 PM
    ControlCar
    Steven
    Sugar Land TX
    just bc I just went through this ground thing last week
    2rz has 3
    One on firewall
    One below diagnostic port(front on intake plenum)
    One on L inner fender(apron) near battery
    my issue was the one by battery
    btw
    mine shows 13.8v-14.2v when running with AC on
    det107 likes this.
  12. Aug 29, 2025 at 8:07 AM
    98tac24
    98tac24 [OP] Member
    Wednesday
    1998 tacoma 2.4
    Took the alternator to the auto parts store, they said it was good, 14+V, tested it twice.
    I notice the battery says 12/21. Seems a little early to be going bad, it was an expensive one. I have it hooked up to a charger now.
  13. Aug 29, 2025 at 9:01 AM
    Glamisman
    Glamisman Well-Known Member
    Where the power wire off the alternator connects inside the BJB, battery junction box, there is a large bolt on fuse, check that too.
    Wulf likes this.
  14. Aug 30, 2025 at 4:48 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Check the fuses located inside the cab.
  15. Aug 30, 2025 at 4:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Buy a new battery, maybe.
  16. Aug 30, 2025 at 4:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'd want to see if we have any voltage drop from the alternator charge terminal to the battery + terminal.
  17. Aug 31, 2025 at 10:00 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It's pretty obvious there is. If the alt is in fact producing 14+ but at the battery it is 11.75 when the engine is running.
  18. Aug 31, 2025 at 1:41 PM
    TnShooter
    Deogee
    STOCK
    May be obvious to you and me. Not OP.
    No one had mentioned it yet.
    Maybe OP can check and update us.
