No data from O2 sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreyF, May 10, 2011.
  1. May 10, 2011 at 4:49 PM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access Cab V6 Automatic
    1999 Toyota Tacoma 2.7L 4x4 standard cab DLX.
    I have installed CAREFULLY the upstream and downstream O2 sensors that were purchased from Toyota dealer. This cleared up the sensor errors I was getting with my OBTD scanner tool. I am pretty sure my catalyst is failing because I keep getting the check engine light periodically and the scan code is P0420. I have to keep clearing this code after driving a little while. I can't find any exhaust leaks that could be causing this either and I have CAREFULLY cleaned the MAF sensor too with the correct cleaner.
    When I do an O2 scan once in a while I notice that I get "no data found" from the downstream sensor and it just shows a "?" mark.
    My question is if the catalyst is not working correctly could this cause this sensor to show no data or should I get this sensor tested even though it is fairly new?
    Is it possible I'm not heating it up enough to get a scan result?
    Below is what my scanner printed out.
    IM Monitors
    Since DTCs Cleared
    Misfire Monitor ok
    Fuel System Mon ok
    Comp Component ok
    Catalyst Mon ok
    Htd Catalyst n/a
    Evap System Mon ok
    Sec Air System n/a
    A/C Refrig Mon n/a
    Oxygen Sens Mon ok
    Oxygen Sens Htr ok
    EGR System Mon ok
    Confirm Selection
    1999
    Codes
    DTCs
    P0420 Mod $10
    Catalyst Efficiency
    Below Threshold Bank
    O2 Monitor Tests
    O2 Bank1 Sensor1
    Lo V for Switch
    MAX: -----(V)
    MEAS: 0.350(V)
    MIN: -----(V)
    MOD: $10
    Hi V for Switch
    MAX: -----(V)
    MEAS: 0.550(V)
    MIN: -----(V)
    MOD: $10
    No data from O2 Bank1 Sensor2?
  2. May 10, 2011 at 5:42 PM
    97_tacoma
    97_tacoma Member
  3. May 16, 2011 at 6:57 PM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    I would like details though on how to test with my DMM without a propane bottle. I'm not sure what to probe exactly on the downstream sensor connector for one thing. My repair manual has no details in it either just general info.
