No drl or turn signal or hazard, right side only
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MJ99, Aug 3, 2018.
  1. Aug 3, 2018 at 7:21 PM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    Hi guys I've got a 2018 taco Sr. I installed anzo head lights. All has been fine until Today the Amber drl led/turn signal just stopped working. Heres the symptoms. No DRL, Entire left side no turn signal, no arrow in the instrument panel for right side, no hazards for right side (front or rear or inside on right). The left, all works as it should. I checked the connection to the headlight and it's fine. At this point I don't believe it's the headlight I think it's entirely electrical. And again all on the right side.
    Thanks in advance
  2. Aug 4, 2018 at 1:33 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Are these lights plug and play?
    LED lights are known to not work in the SRs and SR5s very well unless the aftermarket lights havea built in control module. I’m assuming since there are LEDs in these aftermarket lights, you had to do some splicing. Check those connections, it’s likely coming from one of those.
    If you didn’t splice, then disconnect and reconnect all of the connections, and recheck the lights.
    If that fails, put your stock lights back on and check again. If those work fine, it’s the Anzos. If I remember, a lot of people had issues with the Anzos.
  3. Aug 4, 2018 at 6:47 AM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    They were plug and play. I got those specifically so there’d be no tapping into wires. I’ve done everything besides installing the OEM light back which I’ll do today.
    Still seems crazy that there’s no indicator arrow on the dash for right side and the rear OEM taillight isn’t flashing either. Even with the anzo unplugged. I would assume a rapid indicator but not simply blank. I’ll update in a bit when I switch over the light. Thank you!
  4. Aug 4, 2018 at 10:09 AM
    jmauvais
    NorCal
    ...stuff
    Yah let us know
  5. Aug 4, 2018 at 12:20 PM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    And it was the actual headlight. High and lows work, the white outline works (same plug as the amber DRL/turn signal). Unplugged still no rear blinker. Popped in the oem light and all works. Must be something on the led control module.
    Thanks guys
  6. Aug 4, 2018 at 12:26 PM
    jmauvais
    NorCal
    ...stuff
    Like I said before, a few people have had issues with the anzos.
  7. Aug 4, 2018 at 12:32 PM
    jmauvais
    NorCal
    ...stuff
  8. Aug 4, 2018 at 12:47 PM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    I really appreciate that! Hadn’t seen these before. Thanks
