No electrical power
Discussion in 'Technical Chat' started by adbergmann87, Nov 13, 2018.
  1. Nov 13, 2018 at 8:45 AM
    adbergmann87
    adbergmann87 [OP] Member
    addison
    1996 Red tacoma base V6
    Need help! My 96 Tacoma pretty much died on me when I was working. I have no power to anything not even the door chime goes off. Any advice would be greatly appreciated!
    Things I've done so far, I changed the battery and alternator, battery cables cleaned and are tight, there's continuity, fuses are good. Don't know if I'm missing something to check.
  2. Nov 14, 2018 at 12:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    time to break out the meter and get some real world numbers.
    So you have no idea what the problem is yet changed a battery and alternator.
    This happened while the truck was parked nothing happened prior ?? Charge light not on?? Slow or no cranking??
  3. Nov 14, 2018 at 3:21 AM
    adbergmann87
    addison
    The truck gave no warning as to when it died. One minute it was running then it wasn’t, which was very odd to me.
    Also when this initially happen I would be able to get the truck running for about 15 mins before it died. Now I can’t even get the door chime to go off.
    When I was able to turn it over started with no problem. But it took some time to get it to turn over. So I’m baffled by this.
  4. Nov 14, 2018 at 3:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Give us battery specs. Is the new one new, or borrowed?
    Why did you replace the alternator on a non running truck?
  5. Nov 14, 2018 at 4:04 AM
    adbergmann87
    addison
    I changed the alternator because of the way it shut off gave me the impression it was the alternator. So as of right now the battery is dead.
  6. Nov 14, 2018 at 4:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    You'll need a healthy, fully charged battery to be able to do diagnosis.
  7. Nov 14, 2018 at 4:25 AM
    adbergmann87
    addison
    Ok. I’ll get the battery tested to make sure it’s still good and go from there, and reply back.
  8. Nov 14, 2018 at 6:06 AM
    96carboard
    96carboard Well-Known Member
    Something wrong with hooking up a charger?
  9. Nov 14, 2018 at 8:41 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    battery cables could be "corroded" under the insulation.
    joeyv141 likes this.
  10. Nov 14, 2018 at 10:20 AM
    96carboard
    They're copper, but yeah, they could be *oxidized*.
    ("Rust" is a word that specifically refers to IRON oxide).
    Ground leads are a common failure point. Not just the wires themselves, but the connection to the chassis.
    Test everything for voltage and continuity.
  11. Nov 20, 2018 at 3:26 PM
    adbergmann87
    addison
    So I don’t have a charger but was lucky to exchanged the battery for a new one, but the weather hasn’t been cooperating with me it’s been raining, snowing and just cold. The battery cables is something to investigate if they rusted inside the insulation.
  12. Nov 21, 2018 at 5:40 AM
    96carboard
    Like I said already: BATTERY CABLES ARE NOT MADE OF IRON, SO THEY CANNOT RUST.
    Buy a battery charger. That's your first priority. Doesn't have to be a huge one, but it does have to be a GOOD one.
