No fender flare mud flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by edteach, Sep 13, 2019.
  1. Sep 13, 2019 at 6:12 PM
    edteach
    edteach [OP] Active Member
    I bought a set of mud flaps off of ebay. They said form fit. I plugged in my specs and it said they fit this model. They did not have specs on fender flairs or not. My truck does not have them and they did not fit at all. Where can if pick up a set of non FF mud flaps for a 2012 Tacoma?
  2. Sep 13, 2019 at 7:06 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Market place, Craigslist, Dealer parts dept.
    There are plenty of take-offs.
    I removed mine, cut 2 1/4" off to square them up and put them back on.
  3. Sep 14, 2019 at 7:54 AM
    Pigpen
    Dan
    Northwest Montana
  4. Sep 14, 2019 at 8:06 AM
    edteach
    I did not know that the fender flares had anything to do with the lugs. Mine is 5 lugs.
    Skyway likes this.
  5. Sep 14, 2019 at 11:54 AM
    Skyway
    Ande'
    St.Pete
    Mine is 5 lugs as well.
    Shop Craigs list or buy some RG.... I think that's the name of them
    Found it
    https://rekgen.com/collections/rek-mesh-off-road-mudflaps
    REK-mesh Universal Offset Mud Flaps
    from $220.00
    Toyota Tacoma 'Merica Mud Flaps
    Regular price $105.00
    Universal Rally Edition Mud Flaps
    Regular price $45.00
