No flash on door lock after flasher relay replacement
Discussion in 'Lighting' started by metrick1215, Jan 24, 2022.
  1. Jan 24, 2022 at 3:10 PM
    metrick1215
    metrick1215 [OP] Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    2008 Tacoma 4x4..
    i bought some led turn signal bulbs for my taillights and wanted to get rid of the hyperflash without cutting wires with resistors. So I bought the led flasher relay from advanced auto, and now when I lock or unlock the doors the the lights don't flash.everything worked before relay replacement, just had hyperflash. Anyone know of a reason why? Or is the relay I got bad? Or something I can check. Please and thank you for any advice.
  2. Jan 25, 2022 at 2:45 AM
    caribe makaira
    Caribbean, Puerto Rico
    Are the front turn signals LED's also?
  3. Jan 25, 2022 at 4:00 AM
    metrick1215
    Habersham GA..
    Yes. They have been for a few years. And I've had led turn signals in the rear for awhile also. Just changed bulbs. Also tried the older bulbs with same results.
    I had the stock tails that I had cut resistors in, but one got broke in the snow. So I replaced the pair of tails and don't want to cut the stock wires like I did before.
  4. Jan 25, 2022 at 4:14 AM
    caribe makaira
    If all worked "fine" before the relay change, I'd say it's the new relay.
  5. Jan 25, 2022 at 6:54 AM
    metrick1215
    Habersham GA..
    pretty much what im figuring. Any suggestion on a Relay brand that should work? After pulling relay to look at brand and part# i found a lot of reviews that say this one takes away the flash on locking. Its not a big deal but it is nice since i dont have the alarm in my truck and would be nice to see that the doors locked when button is pressed.
    the one i have is the Novita LM449 LED/2-4lamps. only one advance had.
  6. Jan 25, 2022 at 2:44 PM
    caribe makaira
  7. Jan 25, 2022 at 5:23 PM
    metrick1215
    Habersham GA..
